My hole covers are falling off
Discussion in '1st Gen Tundras (2000-2006)' started by pirates712, Jun 5, 2025.
  1. Jun 5, 2025 at 11:26 AM
    pirates712
    pirates712 [OP] New Member
    Rochester NY
    2000 V8 AC 4x4
    I bought a kit for spraying fluid film and did a few test areas on the truck. Next day, I see these squares of rubber are falling off. Looks like they cover some holes in the rocker panel? Looking at the parts diagram it looks like there's supposed to be a rubber plug (part # 90950-06060, $3.19). Question is, why does my truck not have those plugs and why does it have adhesive squares instead? Does anyone else have these?
    G_unit3000 likes this.
  2. Jun 5, 2025 at 11:30 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Maybe your truck had the OEM step rails at one time and a PO removed them and covered the holes to avoid intrusion? :notsure:
  3. Jun 5, 2025 at 11:34 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    My truck did have the oem step rails and I removed them, you can see two of the bolts in the background of the first picture. I didn't add the rubber adhesive squares though.
  4. Jun 5, 2025 at 11:41 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    JasonC. and pirates712[OP] like this.
  5. Jun 5, 2025 at 11:44 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Jun 7, 2025 at 10:31 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I had the same issue when spraying Fluid Film for the first time this past fall. I pulled those rubber adhesive squares half way off to spray in there but then most fell off within a week.
    I don't recall exactly which of these plugs I used, but it was either the 5/8, 3/4, or 7/8 inch plugs. I could check the box if you like
    The Black Mamba likes this.
  7. Jun 7, 2025 at 12:09 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Thanks! I ended up ordering the Toyota ones, but we'll see whether that part number is rubber plugs or the adhesive squares.
  8. Jun 7, 2025 at 1:28 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I can't see them sending you pieces of tape.
    Good luck.
    [​IMG][​IMG]
    The Black Mamba and G_unit3000 like this.
  9. Jun 7, 2025 at 2:48 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    But that begs the question, if the parts diagram shows rubber plugs, why did/does my truck and @G_unit3000's truck have adhesive squares?
  10. Jun 7, 2025 at 2:53 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Not sure if it's related, but a PO removed running boards mounted to the body and then installed nerf bars mounted to the frame on my 2005 DC.
  11. Jun 7, 2025 at 2:59 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
  12. Jun 7, 2025 at 7:19 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
  13. Jun 8, 2025 at 5:27 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    More research needs to be done. Maybe update the thread and add a poll to see who has what. There maybe something to the fact that both trucks started life out with OEM running boards.
    1lowlife and G_unit3000[QUOTED] like this.
  14. Jun 9, 2025 at 1:32 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Well, went to pick up my parts order and I was handed a bag of adhesive squares. They were immediately returned.
    A set of generic hole covers are on order.
    G_unit3000 and The Black Mamba like this.
  15. Jun 9, 2025 at 2:44 PM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    I had those adhesive squares on my 03 AC as well. When I installed OEM steps I didn't utilize any of the holes; in fact I had to use a rivnut tool to mount them.
  16. Jun 12, 2025 at 3:44 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    3/4" turned out to be the closest. The actual hole is maybe 1/16" less so I had to tap the plastic plugs in with a hammer, but they do fit and they're not falling out.
