Constant hot and ACC fuses for parking mode on Rove R3 Dash Cam on 2023 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by WhiteDevil1978, Jun 6, 2025.
  1. Jun 6, 2025 at 11:37 PM
    WhiteDevil1978
    WhiteDevil1978 [OP] Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    It took a good bit of reading and trial and error to come up with what fuses I needed to tap in to when installing a Rove R3 dash cam with parking mode enabled using the optional hardwire kit sold my Rove, so I am creating this thread for a one stop shopping experience to make this easier for the next guy.
    The fuse box utilized for this project on my 2023 Tundra SR5 TRD-Off Road is the fuse box below the passenger side dash.
    There are two fuses that must be tapped in to. One being constant on power and the other ACC. Below is a diagram of the fuse box (Fuse box 3 location 3). The exact fuses are circled in blue and noted whether it is constant on or ACC. Concerning which wire goes where in the Rove dash cam hardwire kit, the red wire is constant power, the yellow wire is ACC.
    Another problem I encountered was that I could not get the camera to recognize the hardwire kit when trying to turn on parking mode. There are two USB Input/output ports on the Rove R3. For the hardwire kit to work, you MUST use the USB C port on the back of the camera and NOT the port located on top of the camera. Try turning on parking mode with the truck started and doors closed. If that doesn't work, try it with ACC power on in the vehicle, and again with all doors and tailgate closed.
    Hopefully this will help someone avoid the headache I had.
  2. Jun 12, 2025 at 12:56 AM
    MetalMike2112
    MetalMike2112 New Member
    2024 Ice Cap Tundra Limited TRD Off Road I-Force Max
    Thanks For The Good Information. I Have A VIOFO A229 Pro To Install. I'll Be Using Two BlackVue Batteries To Help For Parking Mode And Not Run The Truck Battery Down Any. Those Batteries Will Recharge When I'm Driving. I Have To Hardwire Mine Also For Park Mode To Work. I Ordered The Newest DONGAR Install Kit That Taps Into The Mirror, They Claim Park Mode Will Work, It Doesn't On A VIOFO. That Is On My 2024 Limited TRD Off Road.
  3. Jun 12, 2025 at 12:59 AM
    WhiteDevil1978
    Dustin
    I did the SAME THING! The Dongar does supply power to the camera, and that is how I used it for about two years. So it's not just the Viofo camera. It ie also the Rove R3. It was a clean and relatively inexpensive way to power the camera, but the Dongar does NOT work with parking mode. Now you don't have to feel so bad.
  4. Jun 12, 2025 at 12:44 PM
    mwrood
    mwrood New Member
    Which model Dongar kit did you purchase that doesn’t work with parking mode?
