  1. Jun 10, 2025 at 11:51 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's a nice badge one of my all time phrases growing up in the 80's. Unless I'm missed the boat.:rolleyes:
    OldGuy03 likes this.
  2. Jun 11, 2025 at 2:07 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Those of you who had your cap break, did you have to find the broken pieces in the radiator? I’m not sure if it broke inside or when someone took it off at some point
  3. Jun 11, 2025 at 2:36 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What's the realistic possibility that someone else would have need to remove your radiator cap? From what I've read here, some have found that the missing bit interfered with the thermostat and they had either overheating, or not warming up in a timely manner, issues. I think others have found it in their radiator.
    joseph_womack[QUOTED] likes this.
  4. Jun 11, 2025 at 4:12 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    I replaced the rad when the pieces couldn't be found.
  5. Jun 11, 2025 at 4:24 PM
    zeekevin
    zeekevin New Member
    Myself and may other members found the broken piece in other parts of the cooling system which caused abnormal temperatures
    https://www.tundras.com/threads/2008-tundra-5-7-temp-issue.59514/
    OldGuy03 and Wynnded like this.
  6. Jun 11, 2025 at 10:39 PM
    joseph_womack
    Joe
    Louisiana
    I have pulled an aluminum piece out from where the cap sits; but the spring and the lower plastic piece I haven’t seen… I’m the only one to touch this truck for the last 5 years, but my brother took it to shops before that and the previous owner took it to Toyota
    coolant temps are fine and have been fine but I’ll pull the upper hose off to see if I can find the spring
    I have also wanted to flush the coolant so this is just an added reason to… time to add it to the ever growing list
  7. Jun 12, 2025 at 1:45 PM
    EmergencyMaximum
    Reposting. I was in the wrong 2nd gen.
    Yes sir'ee!! Oil change tome!!
    joseph_womack likes this.
  8. Jun 12, 2025 at 3:28 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    your attempt at getting a photo is sending me off a cliff right now :rofl:
  9. Jun 12, 2025 at 5:50 PM
    EmergencyMaximum
    Thos was faster. Lubed-up hands
