Oem jbl amp replacement
Discussion in 'Audio & Video' started by Jxiong503, Jun 5, 2025.
  1. Jun 5, 2025 at 6:41 PM
    Jxiong503
    Jxiong503 [OP] New Member
    Hi. I have a tundra with JBL system which includes the JBL amp. If i buy a aftermarket amp with high level input option do i still need a device like the DSR1 before the aftermarket amp to eliminate my oem JBL amp? Or can i plug the input signal at my oem JBL amp into the aftermarket amp without needing a DSR1?
  2. Jun 11, 2025 at 7:06 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
    The OEM JBL amp controls other things to include fade, etc. You'll lose some of those controls if you bypass the OEM JBL amp. James at https://tech12volts.com/shop offers a plug and play harness and DSP JBL amp. The DSP JBL amp takes high level input from your existing OEM JBL amp, uses a built in software based EQ and crossover that James and team tune specifically for Tundras and then sends the output to your existing speakers. I went this route and was extremely satisfied with the results. I also upgraded the subwoofer.
