Winch wiring 25 hybrid
Discussion in '3rd Gen Tundras (2022+)' started by GWolf, Jun 11, 2025.
  1. Jun 11, 2025 at 8:44 AM
    GWolf
    GWolf [OP] New Member
    Greg
    2025 Tundra 1794 Factory lift, TRD, PP
    RCI protection, RCI bumper, 12k winch.
    I looked through the search of previous threads and didn't find anything. I apologize if it has been previously addressed. Im curious the recommend way to wire my winch.
    Option 1: using the lugs on the fuse box drivers side. Use multi meter with truck running to verify power and ground. Install disconnect.
    Option 2: run wires to the battery under rear seat drivers side. (Not going to be fun or easy)
    Thanks for the help.
    2025 tundra 1794 lunar rock, oem 3in lift, pp, full under protection.
  2. Jun 11, 2025 at 2:52 PM
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
  3. Jun 11, 2025 at 4:26 PM
    GWolf
    Greg
    Ya, I saw that. I think it's a little pricey and I still need to run wires to the battery which is the correct way to do it. Option one is not safe apparently. I bet I can't ghetto fab something cheaper after I run the wires. I'll look more into it but it just looked like a lot of money for two terminals and a bracket. Maybe I'm missing something. No budget restraint.
