Ravenol Transfer Case Fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigfoot17, Jun 11, 2025.
  1. Jun 11, 2025 at 1:11 PM
    bigfoot17
    bigfoot17 [OP] New Member
    2018 Crewmax TRD Off Road
    I recently just purchased 2 liters of ravenol 75w mtf-3 oil to change out the transfer case fluid on my ‘18 tundra which has an automatic transmission. The oil states it’s for manual transmission. I didn’t realize that until delivery. I’m guessing I can’t use this?
  2. Jun 11, 2025 at 1:18 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Your transfer case is separate from your transmission, 2 different types of fluids. Ravenol 75w mtf-3 is a well-recommended fluid for your t-case, you can use it with no problem. Have the same fluid in mine, 2021 SR5.
    Don't put that in your transmission.
  3. Jun 11, 2025 at 1:23 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    2nd note and vote for Ravenol 75W in your Gen. 2.5 Tundra xfer case.
  4. Jun 11, 2025 at 1:35 PM
    AZTundra
    Paul
    Phoenix, AZ
    No problems with the ravenol fluid. I just did my transfer case recently.
    BrandonL812 and TheBeast like this.
  5. Jun 11, 2025 at 2:10 PM
    bigfoot17
    That’s what I’m swapping out, the transfer case fluid, not the transmission fluid.
  6. Jun 11, 2025 at 2:10 PM
    Mr Badwrench
    Mr Badwrench New Member
    The transmission and transfer case do not share oil. Make sure you identify the transfer case fill/drain plugs before tearing into it.
  7. Jun 11, 2025 at 3:54 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I just got my entire kit from them. Looking forward to doing it next month.
    75w is only for the middle transfer Case. Their kit comes with 2 weights.
  8. Jun 14, 2025 at 3:07 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Same here with the Ravenol 75W listed for transfer case
