Stripped T30 Bolt (Bed Rails)
Discussion in '3rd Gen Tundras (2022+)' started by SithLord92, May 22, 2022.
  1. Feb 27, 2023 at 8:25 AM
    #121
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    If you need to replace the deck rail screws due to damage, here is the p/n for the replacement standard length screws: 90148-A0012
    They run about a buck each.
    Hightechredneck likes this.
  2. Feb 27, 2023 at 9:06 AM
    #122
    Moon
    Moon New Member
    2013 Tundra grade crewmax
  3. Jun 9, 2025 at 7:40 PM
    #123
    Hightechredneck
    Hightechredneck New Member
    Rob
    2016 Tundra Double Cab
    2025 and I have the same problem, going to get the cutoff wheel tomorrow. Wish me luck!
  4. Jun 9, 2025 at 9:41 PM
    #124
    Manutd818
    Manutd818 New Member
    2024 Tundra Limited Trd off-road
    I guess you’re in a better position than me. Fucken bolt completely broke off in my bmw aluminum engine block. Tried everything, made it worse lol. Payed a specialist to get everything back to what it was. Was replacing the oil filter housing gasket, didn’t even overtighten or anything, it just decided it was time to break off.
  5. Jun 10, 2025 at 1:14 AM
    #125
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Drill it out and use an extractor..
  6. Jun 11, 2025 at 12:18 PM
    #126
    Hightechredneck
    Rob
    Well they are out, used two different methods.
    AZBoatHauler likes this.
