Need help picking lift setup
Discussion in 'Suspension' started by Tony9th, Jun 11, 2025 at 11:17 AM.
  1. Jun 11, 2025 at 11:17 AM
    Tony9th
    Tony9th [OP] New Member
    Wednesday
    Tony
    I recently purchased a 24 Tundra 1794 non-hybrid and wanted to install a small lift (~3 inch). I'm torn between two separate lift kits:
    - 3.5" Rough County Lift with Vertex Coilovers and V2 rear shocks for $1,199
    - Bilstein 6112 Coilovers and 5100 in the rear for $1,061
    I know Rough County has a bad rap, but I've heard decent thing on the Vertex Coilovers. The Bilsteins should be pretty solid, but I'm only getting about 2.2 inches of lift.
    Thoughts?
    Thanks,
    Tony
  2. Jun 11, 2025 at 11:45 AM
    SoAzTundy
    SoAzTundy New Member
    2024 WCP Platinum TRD OR
    between those 2 Id go with the bilsteins. Given a 3rd option Id go with the Eibach stage 2r. No cost issue option ADS. What I am buying is a Ready Lift 3" with Falcons.
  3. Jun 11, 2025 at 11:56 AM
    SATX-TUNDRA
    SATX-TUNDRA New Member
    2024 Toyota Tundra Limited 4x4
    I have the 3.5" RC lift with the M1 coilovers and shocks. The ride did get a bit stiffer compared to the factory non-trd suspension that was on the truck, which I am ok with. I felt like the stock suspension would fall out if I hit a hard enough bump in the road. One thing I did was to replace the front CV axles with the Ready Lift axles that are recommended with their 3-inch kit. My truck came with the black axles, which may or may not have worked but I did not want to take the chance.
  4. Jun 11, 2025 at 12:44 PM
    Tony9th
    Wednesday
    Tony
    The main reason I'm considering the Rough Country is the Vertex Coilovers by themselves are typically $1,299. The 3.5-inch with Vertex front and rear is $2,839. I've only found one site that pairs the Vertex front with the V2 rears and the price comes in less than the 3.5-inch with M1s. I can't find any reviews between the Vertex and Bilstein 6112 Coilovers.
  5. Jun 12, 2025 at 8:18 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    We have a few different options here in stock right now ready to ship, our Aluma 2.5 coilover kit, rear shocks, coils, etc etc - 10% on the product right now too! Let me know if you have any questions!
