General Supercharger Thread
  1. Jun 11, 2025 at 8:56 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Can't pump your own gas in Mexico.
    No luck on the fusible, still no crank. Starter I ordered Monday hadn't shipped so I called the dealer in CA. I used to get no tax/free shipping, 2-3 business days for them to get it from today. I called my local, they can have it Friday so I ordered it, cancelled the first one. :(
  2. Jun 11, 2025 at 9:07 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Wow, I just received main and rod bearings that I ordered in 2021 and completely forgot about...gotta be some kind of record
  3. Jun 11, 2025 at 9:08 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Does the engine crank fully by hand? Like several full rotations?
  4. Jun 11, 2025 at 9:09 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe mine is due to a tight belt also, but then again 13 years of use isn't too bad.
    My belt is tight. I have to do a water pump change and I might order a smaller billet pulley from ASP. Think it's $150 that they sell with their larger crank pulley. I just never got one when I went with their crank pulley.
  5. Jun 11, 2025 at 9:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Edit...I didnt read...
    HulkSmurf14 likes this.
  6. Jun 11, 2025 at 9:19 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Had some problems with the belt tensioner pulley in my 98 Tacoma years back.
    The bearing kept failing and they'd only sell you the complete pulley with the bearing installed.
    Made my own pulley out of 316 Stainless and pressed in a sealed German speed bearing intended for skateboards.
    Never had another problem with it.
    M3Tundra-JK likes this.
  7. Jun 11, 2025 at 9:33 AM
    centex
    centex New Member
    I laughed way too hard at that. That’s awesome.
  8. Jun 11, 2025 at 9:46 AM
    e30cabrio
    I just cranked on it for over a minute, forgot to mark the belt to see it was going around, but sure felt like several full rotations. I have only 2 plugs out, and I felt the lower compression (easier to move) on those strokes 3x
  9. Jun 11, 2025 at 10:19 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    WTF hahahaha, should leave a review "5 stars, shipped in a timely manner, only took 4 years 3 weeks"
  10. Jun 11, 2025 at 10:24 AM
    blenton
    blenton New Member
    #WhippleLife
  11. Jun 11, 2025 at 10:32 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I originally told him no, I got it, but then he told me it’s a law. Frickin Jersey.
    Tundra Texan[QUOTED] and Mdl like this.
  12. Jun 11, 2025 at 10:54 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Ha! Had something happen similarly in the early 2000's with Clutchnet. Had an order for a dual friction clutch disc that was waiting on a batch run, I forgot about it and went to something else, then 2 years later they find the paper order slip on the floor behind the desk. Luckily they called first before shipping.
  13. Jun 11, 2025 at 12:19 PM
    e30cabrio
    In case anyone is thinking, just do it yourself.
    It's mid 80's at 5am, soon it will never be under 90 :(
    It literally just went to 116!
  14. Jun 11, 2025 at 12:20 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    yeah, but it's a dry heat! J/K
  15. Jun 11, 2025 at 12:35 PM
    snivilous
    SW UT
    I cannot comprehend why anyone would live in the Phoenix area, but power to you :D
  16. Jun 11, 2025 at 12:37 PM
    e30cabrio
    Me either.
    Moved here for 6 months in 2006.
    Reminds me of the song stuck in Lodi.
    https://youtu.be/ACQSs1sTFYc?feature=shared
    Lol
    Tripleconpanna, HulkSmurf14 and Mdl like this.
  17. Jun 11, 2025 at 2:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that you have no choice but to become nocturnal.
  18. Jun 11, 2025 at 2:49 PM
    e30cabrio
    I am nocturnal, generally up about 3-4am, but it's dark & still mid 80s even then, very soon, never under 90 :(
    Tripleconpanna likes this.
  19. Jun 11, 2025 at 3:03 PM
    mralanle
    mralanle New Member
    Getting an P2198 code. When I google it, it shows others that get the same code has another code with it but my truck is only getting the P2198. Has anyone ever encountered this issue?
    2015 with TVS1900, DW650 injectors, PS fuel rail and FPR, walbro pump
  20. Jun 11, 2025 at 3:14 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    recently boosted?
    run fine for a bit or is this right off the tune/install?
    code is for rich condition, pre cat. prob bad o2 sensor imo
    how does the truck drive?
    edit - do you have afr gauge to verify how rich it's running?
  21. Jun 11, 2025 at 3:17 PM
    mralanle
    mralanle New Member
    It was fine for a bit, I started noticing a check engine light coming on when I drove in the rain. It hasn’t came back when I cleared it until a few days ago. It will come back 5 mins after I clear it now.
  22. Jun 11, 2025 at 3:19 PM
    e30cabrio
    Two questions: do I need an adhesive for the O-Rings? Looks like it had some.
    Also, I assume for assembly I needed a bolt in the middle opening? It was not there.
    Can I use this?
    ARES35 and HulkSmurf14 like this.
  23. Jun 11, 2025 at 3:19 PM
    carn_dogg
    Pat
    Eastern Shore MD
    how long is a bit?
    miles since blower was installed and truck was tuned?
    could be bad o2
    could be stuck inj
    does your exhaust smell like fuel?
    rough idle?
    misfire?
    also - are you running an oiled air filter? if so, clean MAF and install dry filter
  24. Jun 11, 2025 at 3:21 PM
    mralanle
    mralanle New Member
    Yeah, about 2-3 thousand miles. I barely drive the truck. Yes exhaust smells like fuel but thought that was because I have headers as well. No misfire, no rough idle
  25. Jun 11, 2025 at 3:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I hope I don't get flamec but with older o-rings I'll roll a bit of fipg to get them to stay put. If it's on a slow setting and not cross threaded but don't take the chance.
  26. Jun 11, 2025 at 3:22 PM
    carn_dogg
    Pat
    Eastern Shore MD
    i would clean MAF (and install dry filter if you have an oiled one in there), clean o2, see how she does.
  27. Jun 11, 2025 at 3:24 PM
    mralanle
    mralanle New Member
    Gotch, I’ll clean the MAF again, I cleaned it recently when I installed the AFE pro dry filter. I also switched from the Trd box that came with my super charger to a buddies magnuson if that matters at all, im told they’re the same thing.
    mustang67408 likes this.
  28. Jun 11, 2025 at 3:27 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Right there with you--- here in Nevada :(:(:(
    was 110 yesterday at work
  29. Jun 11, 2025 at 3:28 PM
    carn_dogg
    Pat
    Eastern Shore MD
    copy on airbox and filter, good there if the same size.
    check obd data to see real time afr on the o2 sensors
  30. Jun 11, 2025 at 3:28 PM
    VWTim
    Corvallis, OR
    Measure the TB hose opening on the new vs old air box. There are 2 sizes of TRD box lids, changing sizes without a retune would cause a rich/lean issue
