How high can you stack a pile of chit?
Discussion in 'Outdoors' started by Half Assed, Jun 1, 2025.
  1. Jun 7, 2025 at 11:36 AM
    #91
    7367 lbs.
    ZappBrannigan likes this.
  2. Jun 7, 2025 at 11:51 AM
    #92
    Half Assed
    Half Assed [OP] me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Yes is does now. I also got a cheap canopy for it so it'll be mostly out of the rain when i'm not using it.
  3. Jun 7, 2025 at 1:16 PM
    #93
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Are there any screws in the wooden framing, or just staples?
  4. Jun 7, 2025 at 2:29 PM
    #94
    rmiller139
    rmiller139 New Member
    2011 Tundra DC
    Eibach 2R kit w/ Icon UCA BAK revolver
    Here for the party
  5. Jun 7, 2025 at 7:00 PM
    #95
    Half Assed
    Heartland Florida
    It's a mixture of both. The framing is stapled together into different sections and screwed together. Not much too it. For $30k you can have a brand new one! :puke:
  6. Jun 7, 2025 at 7:02 PM
    #96
    Well, what was the weight?
  7. Jun 7, 2025 at 7:44 PM
    #97
    Half Assed
    Heartland Florida
    5600 with me in it.
  8. Jun 7, 2025 at 7:51 PM
    #98
    Half Assed
    Heartland Florida
    I picked up some quarter plywood tonight to skin the wall with tomorrow after i scab in the corners.
  9. Jun 7, 2025 at 8:08 PM
    #99
    With the camper?
  10. Jun 7, 2025 at 8:24 PM
    #100
    Half Assed
    Heartland Florida
    No that's empty weight.
    OldGuy03 and ColoradoTJ[QUOTED] like this.
  11. Jun 8, 2025 at 3:22 PM
    #101
    Half Assed
    Heartland Florida
  12. Jun 8, 2025 at 3:49 PM
    #102
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    That's a pretty good looking slice of plywood paradise. I assume the white between all the studs is insulation? Are you going to stain or paint the ply?
    Blue Thunder likes this.
  13. Jun 8, 2025 at 4:13 PM
    #103
    Half Assed
    Heartland Florida
    Yeah styrofoam. I have a bunch of white trim paint, so I'll probably use that.It may not get done until after we get back though. I'm planning to build some clothes cubbies on each side of the bed with quarter sanded plywood. The regular plywood will be on the inside and won't be seen as easily.
  14. Jun 8, 2025 at 4:46 PM
    #104
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I'm known for doing some sketchy shit, but that's a few steps too far past the line for me. Especially for a honeymoon.
  15. Jun 8, 2025 at 6:23 PM
    #105
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    I apologize if someone else said this… I read the beginning and clicked to the end as fast as I could. I’ve been married 22 years. A honeymoon is not the time to try this for the initial run. Do plan b c or d . Some of the memories this might create aren’t the ones you want. Rent an rv perhaps fully stocked and focus on something else other than .. can we make it.
    SD Surfer likes this.
  16. Jun 10, 2025 at 7:06 PM
    #106
    Half Assed
    Heartland Florida
    No faith in the Toyota. That should be a bannable offense. :amen:
  17. Jun 10, 2025 at 7:08 PM
    #107
    Half Assed
    Heartland Florida
    Had some time to start on the bed floor tonight.
    Went with 2x4s instead of the original 1x4s.
  18. Jun 10, 2025 at 7:21 PM
    #108
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i’m really surprised a rcsb is that heavy. Are you 4x4?
  19. Jun 10, 2025 at 7:49 PM
    #109
    Half Assed
    Heartland Florida
    Yes with a heavy front bumper and a winch with 3/8" cable. It's only two rear doors and a bench seat short of a doublecab.
    My 95 f150 4x4 was about 4600. But it was made of swiss cheese and tin foil. If you're worried about frame flex go drive one of those.:laughing:
  20. Jun 10, 2025 at 8:23 PM
    #110
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My ‘02 ac is less than 5k with a cap, some bed interior, and a fridge & battery. But that was a junkyard scale. Kinda thought the other tundras were mostly hot air.
  21. Jun 14, 2025 at 1:10 PM
    #111
    Half Assed
    Heartland Florida
    The nose is mostly back together on the outside. Needs more sealant.
  22. Jun 14, 2025 at 1:12 PM
    #112
    Fine looking work so far!
    BlackNBlu likes this.
  23. Jun 14, 2025 at 1:23 PM
    #113
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Good idea to reinforce the bed area since this is the honeymoon.
  24. Jun 14, 2025 at 1:27 PM
    #114
    Half Assed
    Heartland Florida
    My wife booked a campsite next weekend. Still lots to do. Tomorrow i gotta slap on the airbags and swaybar. Weld up the tie downs. Hellwig still hasnt shipped the add a leaf after a month....
    I was worried about the tie down points on the camper so i did some investigative cutting. One isn't very solid at the rear drivers side and i want to fix it. The others have eyebolts through the framing so i'm not too worried about them.
    The tie down in question: The plywood here is soft and needs to be replaced at some point. But for now i think I will try to cut a hole next to the outdoor shower to get an eyebolt through the framing here also.
  25. Jun 14, 2025 at 3:21 PM
    #115
    Half Assed
    Heartland Florida
    Pfft. Ain't going no where.
  26. Jun 14, 2025 at 3:36 PM
    #116
    j-utah
    j-utah lost member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    I admire your work ethic and tenacity. Careful with the brakes, and if a deer jumps out don’t stop just floor it you’ll be fine :hattip:
  27. Jun 14, 2025 at 3:44 PM
    #117
    EmergencyMaximum
    At first it was cartoon funny, but Mr.Half assed is gaining much testosterone in my eyes! Beautiful transformation!
  28. Jun 14, 2025 at 6:25 PM
    #118
    Half Assed
    Heartland Florida
    Damn it. There goes $50. Time to go inside the house lol.
  29. Jun 14, 2025 at 7:30 PM
    #119
    EmergencyMaximum
    Pressure treated wood might not be a very good idea to use in that close proximity to humans.
  30. Jun 15, 2025 at 4:57 PM
    #120
    Half Assed
    Heartland Florida
    You're probably right. Can't be any worse than the mold that's probably in there too. Or all the glue and different chemicals off gassing in there. Maybe i'll get a good buzz and sleep better?
    I cleaned the mattress, but it's not coming back. Still stinks like mildew. A new one was $230 but may not arrive by friday. I checked craigslist and got lucky. A brand new short queen 10 minutes away for $100.
