Topper 3rd Brake Light Wiring
Discussion in '3rd Gen Tundras (2022+)' started by trd6x6, Mar 15, 2024.
  1. Mar 15, 2024 at 11:47 PM
    trd6x6
    trd6x6 [OP] Not a truck guy (before)
    Home means NE-VAD-UH
    2023 Lunar Rock Tundra HV Limited
    UPDATE:
    Finally figured out the plug-n-play solution that has no drilling & no tapping. Easy removal as well. Getting power & signal from the trailer connector using the following components:
    Back of trailer connector ->
    -> 1. USCAR 7 pin to 4 pin T harness
    -> 2. CURT 58348 Trailer-Side 4-Pin Flat Wiring Harness
    -> 3. 16 Gauge in-line 5 amp mini blade fuse
    -> 4. IMPORTANT: AT-LC-8N LED 3rd Brake Light Logic Module
    -> 3rd Brake Light
    4 is crucial since some other logic module doesn't work well with LED lights. I used heat shrink tube at all connections and wrapped everything in 1/2 inch split wire loom tubing. It works flawlessly. Hope this is helpful for you guys
    Guys, is there a clean solution to wire the 3rd brake light on topper? I did some research and looks like there are 3 options:
    1. Tap directly to the tail light -- I know there are quick disconnect connectors, but still don't want to mess up with the factory wiring if possible
    2. 7-way to 4-way T harness -- Pro is it's plug n play, but seems the 4-way flat connector is for trailer light, so the 3rd brake light will blink when turns:rolleyes:
    3. FBC harness solution -- not available to the 3rd gen Tundra yet :boom:
    Anyone has experience? TIA
  2. Mar 16, 2024 at 6:13 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Just tap into the brake
    light super easy and clean use the quick connect T taps you can get them pretty cheap on Amazon. You won't have any issues if you do it right and it's hard to screw up. If you bought a canopy brand new that's how they would do it. I personally would avoid using my trailer wiring for it. If you have any thoughts of wiring a light inside your canopy you will need to run a line from the battery if you want it to work when the truck is off so you will need to bring it thru the bed behind the taillight anyway.
  3. Mar 16, 2024 at 6:18 AM
    wing-2
    wing-2 New Member
    Brake and directional use the same lamp, so the truck interrupts the power when the directional is on. So if you grab power at the rear tail light, the brake light on the cap will blink when that directional is on.. If the cap is installed at the dealer, they will make it work.
  4. Mar 16, 2024 at 6:41 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Pretty sure even if it is the same lamp it is a different wire you tap into at least it was on the last couple I did. However I have not done a third gen but to me it makes sense that it has a different source it would have a different wire
  5. Mar 16, 2024 at 8:05 AM
    wing-2
    wing-2 New Member
    On mine, at the tail light, there are only three wires. Running lights, brake/directional , and ground.. PXL_20240316_145639559.jpg
    1lowlife likes this.
  6. Mar 16, 2024 at 8:22 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Here is your brake light wiring diagram.
    Pin 5 lilac wire at your rear light connector.
    Ground is pin 3
    Turn signal is pin 2
    Lavender/sky blue wire on the right
    Beige wire on the left
    Illumination, or parking light is pin 6 lavender/green wire
    That wire color is a tough one to see..:eek::D
  7. Mar 16, 2024 at 8:24 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    That's odd, you don't even have a pin 5...:confused:
    Although I don't know what a 'marker light' is, or the difference between a 'marker light' and a 'rear ID light'..
  8. Mar 16, 2024 at 8:26 AM
    wing-2
    wing-2 New Member
    Mine is an SR5.....
    1lowlife[QUOTED] likes this.
  9. Mar 16, 2024 at 8:33 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Is that diagram for a gen 2 or gen 3? On the tacoma it has a 3 pin but I tapped the wires before the plug which had a brake only wire that spliced into the brake/turn signal pin
  10. Mar 16, 2024 at 8:36 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    I have a canopy on order I guess I will be figuring it out soon enough
  11. Mar 16, 2024 at 8:57 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  12. Mar 16, 2024 at 5:40 PM
    trd6x6
    Does the trim matter? Mine has the sequential turn signal, I know SR5 has different tail light. Maybe wiring is different?
  13. Jul 18, 2024 at 10:15 AM
    cream_based
    cream_based New Member
    So, I've run into the same problem mentioned in this thread in regards to my SR5 having only 3 wires/pins. Did anyone figure this out? I'm just trying to hook up my camper shell's thrid break light.
  14. Jul 20, 2024 at 9:21 AM
    KrissyMattAlpha
    KrissyMattAlpha New Member
    2023 SR5
    2023 SR5 and confirm only 3 pins in the taillight harness. My topper brake light operates just like the tail light its wired to. Meaning its on when braking and flashing when turn signal is engaged. I've been thinking about connecting it thru the trailer harness, but haven't dedicated the time to figure it out.
  15. Jun 9, 2025 at 11:48 AM
    trd6x6
    UPDATE:
    -> 3rd Brake Light
    wing-2 likes this.
  16. Jun 9, 2025 at 5:17 PM
    KrissyMattAlpha
    2023 SR5
    GG offroad has a cable kit that plugs into the brake light harness on the rear of the cab and extends to the topper.
    wing-2 likes this.
  17. Jun 9, 2025 at 11:17 PM
    trd6x6
    I was thinking about using his kit. But it needs access to cab 3rd brake light, also needs to run long wire from cab. Might worth it If you need to relocate the camera at the same time. Otherwise plugging to trailer connector is much easier.
  18. Jun 10, 2025 at 4:56 PM
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    The GG off-road and the one below are the two options I know of, which is basically what the OP did
    https://www.ezwheeler.com/products/...ug-in-t-harness-300200?variant=44528711860468
    I just let my canopy installer handle it. Dome light to the battery, lock/unlock to wires under the driver door sill, and brake light to a wire harness under the hood. That’s what their ‘book’ said to do, which they claim Leer develops with the vehicle manufacturers (who knows). It’s a splice which is a bummer but really not a big deal.
  19. Jun 11, 2025 at 9:47 AM
    KrissyMattAlpha
    2023 SR5
    I'm guessing you don't have the digital rearview camera
  20. Jun 11, 2025 at 10:15 AM
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    Correct.
