Do I need shocks?
Discussion in 'Suspension' started by phabej, May 8, 2025.
  1. Jun 10, 2025 at 11:03 AM
    phabej
    phabej [OP] New Member
    2018 Platnium
    I read somewhere (maybe here or online somewhere) that you have to adjust the driver side 1/2" higher than the passenger side due to the gas tank. Not sure if this is true. But I do have the 38 gallon tank.
  2. Jun 10, 2025 at 11:16 AM
    caboj
    caboj New Member
    CA
    2018 Tundra CM TRD OR
    I didn’t have to touch cam bolts either, not necessary.
  3. Jun 10, 2025 at 11:17 AM
    caboj
    caboj New Member
    CA
    Stock springs account for this, they are side specific. If reusing then ok. With the adjustable coil overs that is correct, will need to adjust to compensate.
    phabej[QUOTED][OP] likes this.
  4. Jun 10, 2025 at 11:18 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  5. Jun 10, 2025 at 1:45 PM
    phabej
    2018 Platnium
