Upgrade Tie Rod Ends
Discussion in '2.5 Gen Tundras (2014-2021)' started by alowther12, Aug 25, 2021.
  1. Aug 25, 2021 at 7:18 AM
    alowther12
    alowther12 [OP] New Member
    Aaron
    2017 Black Tundra
    3.5”/1” lift Cold air intake
    Anyone had any luck finding some heavy duty after market tie rod ends?
    Coachbuilder1 likes this.
  2. Aug 25, 2021 at 7:51 AM
    Project671
    Project671 King of Catastrophe
    Dover AFB
    2011 Rock Warrior CM
    Stuff and Things
  3. Aug 26, 2021 at 11:10 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Let me know how I can help. We build steering upgrades for 2007+ Tundras, all applications. https://shop-coachbuilder.myshopify.com
    coldcanuk likes this.
  4. Aug 26, 2021 at 11:54 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    What coach David said... Beefy and solid!
  5. Aug 7, 2024 at 12:09 PM
    Goofinator
    Goofinator New Member
    Bernard
    I know this thread is old but want to know if it’s worth it? I changed my suspension like 3-4 times in one year finding the right set up for me. So now I have 3.5” lift, UCA and spacer for sway bar but both joints on my tie rod look blown and when turning like in or out of a spot here a clunk. Truck has 40k
    Pig Rig likes this.
  6. Sep 11, 2024 at 9:52 PM
    WolfPac_Outdoors
    WolfPac_Outdoors New Member
    Austin
    Northern California
    2018 Tundra TRD Sport White
    Yes Mucho
    It can be a few things and here’s what I’d check first. The tie rod moving sharply or your UCA is loose and moving sharply. You can take the cotter pin out and remove the castle nut, and then remove the tie rod end from the steering knuckle. If it moves easily it’s getting warn out.
    For the UCA’s loosen the bolts and then grease the bushings through the zerk fittings (if your UCA’s have them), then re-tighten the bolts to spec.
    I’m also in the market for tie rod ends and the ones @Coachbuilder1 has look like they are the best quality in the market.
    Mdl and Coachbuilder1 like this.
  7. Jun 10, 2025 at 9:15 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    My MOOG tie rod ends just went out and they have less than 10k miles on them. Is there a better upgrade out there?
    Mdl likes this.
  8. Jun 10, 2025 at 9:45 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  9. Jun 10, 2025 at 9:51 AM
    AstroDude
    Eddie
  10. Jun 10, 2025 at 10:22 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    They are $$ but for some people it's hard to get their alignment dialed in. There are some cheaper ones out there so research a bit for what works.
  11. Jun 10, 2025 at 10:30 AM
    AstroDude
    Eddie
    I'm good with spending the money if that means the other options fail every year. I noticed that on the MOOG, the bottom of the tie rod end starts to seep out grease.
