Bad wheel bearing
Discussion in '1st Gen Tundras (2000-2006)' started by joeramirez, Jun 9, 2025.
  1. Jun 9, 2025 at 4:25 PM
    joeramirez
    joeramirez [OP] New Member
    2005 TUNDRA DC SR5 4WD V8
    Hello. I have a 2005 Toyota Tundra that needed a wheel bearing replacement and thought if I ordered a used knuckle with a good wheel bearing it would be an easy swap. I Got the used knuckle and it looks like the wheel bearing is also shot but I need your expertise. Picture 1 is the old wheel bearing/knuckle and 2/3 is what I got used from car parts direct with a rusted dust plate that I had to take off. What do you recommend?
  2. Jun 9, 2025 at 4:33 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    The Black Mamba likes this.
  3. Jun 9, 2025 at 4:41 PM
    joeramirez
    Thanks sirfive! Does the original look salvageable?
  4. Jun 9, 2025 at 4:45 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont know, you’d have to get both inner bearing races off, and make sure nothing is chewed up. The ‘new’ one might just need a seal.
    maybe someone thats done it knows if there are ‘inner’ seals, since i see some of em are marked as ‘outer’ seals.
  5. Jun 9, 2025 at 5:24 PM
    joeramirez
    Thank you!
  6. Jun 10, 2025 at 5:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    You've gone to the expense and hassle of getting a new/used knuckle. You'd be crazy to install it without first replacing the bearing and seals -- it's so easy and economical to do with the knuckle off the truck. Are you planning to do the work yourself?
    With a shop press:
    https://www.youtube.com/watch?v=uaUVugUGzx8
    https://www.youtube.com/watch?v=_Yy9-VLahbA&t=901s
    WITHOUT a shop press:
    https://www.youtube.com/watch?v=RIURRRUqdKA
    If you don't have access to a press, take the parts and knuckle to a shop... I bet they'll charge you an hour labor to do the press work.
    I have to do mine soon. I already got the bearing and inner and outer seals from Rock Auto and I have a 20 ton press.
    des2mtn and The Black Mamba like this.
  7. Jun 10, 2025 at 5:43 AM
    joeramirez
    Thanks tvpierce! You’re right so I will have a friend replace them for me. Which part #s did you get from Rock Auto?
  8. Jun 10, 2025 at 5:56 AM
    tvpierce
    Maine
    Here are the parts for my 2000 AC. I don't know if they are different for your truck because you don't have your truck info in your profile. You need to add that info so people can better help you.
    Go to your profile and add the year, cab style (RC, AC, DC), trim package (SR5 or Limited), 4WD/2WD, and engine (V8 or V6)
  9. Jun 10, 2025 at 6:36 AM
    Koyo was the OEM supplier for the front wheel bearings. I would use those.
    There is an inner and outer Sheild you need to replace as well.
  10. Jun 10, 2025 at 7:11 AM
    tvpierce
    Maine
    Rock Auto didn't have Koyo, so I went with SKF -- which is another quality bearing company. In fact, SKF is the OEM supplier for the rear axle bearings. I would feel comfortable with Koyo, SKF, or Timkin.
  11. Jun 10, 2025 at 7:44 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    The OEM rear bearings for my '00 say Nachi on them
    tvpierce likes this.
  12. Jun 10, 2025 at 8:35 AM
    tvpierce
    Maine
    Correct. When I replaced my rear axle bearings, I ordered SKF from from RA -- here's a pic of one alongside the aftermarket bearing I removed from the axle. If you look closely at the SKF bearing (lower/brown seals, next to the SKF box) it says Nachi in the lower right @ about the 4-5 o'clock position. I was a little unsure of the SKF bearing, so decided to order a set of OEM bearings from a Toyota dealer (I figured I didn't want to be doing this job twice.) The bearings came from Toyota, and they were exactly the same as the SKFs: brown seals that said Nachi/Japan -- so I returned the Toyota bearings because they were about twice the price.
  13. Jun 10, 2025 at 9:25 AM
    Timkin ain’t what they used to be
    tvpierce and Redoak like this.
  14. Jun 10, 2025 at 10:54 AM
    tvpierce
    Maine
    Oh man, don't tell me that. I just installed Timkin rear bearings on my wife's Subaru. I guess we'll see.
  15. Jun 10, 2025 at 11:35 AM
  16. Jun 10, 2025 at 11:46 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    The Japan built units have NTN bearings while the USA built units have SKF
  17. Jun 10, 2025 at 12:00 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Iirc koyo bought them. Did they really get worse?
