Rear Dash Cam
Discussion in '1st Gen Tundras (2000-2006)' started by Fragman, May 14, 2025.
  1. May 14, 2025 at 3:00 PM
    Fragman
    Fragman [OP] New Member
    2006 Tundra DC SR5 2WD V8
    Sorry about this. I can't seem to find the thread where I thought I saw someone had done this.
    For those with a DC (and therefore a power sliding rear window) that have a rear dash cam, where/how are you mounting it? I'm toying with sliding some kind of bracket under the headliner at the rear, but ideally want to see how others have done it. A 3D printed part, even PETG might have a hard time holding up in the Texas heat. Just wondering if anyone has already solved this problem?
    G_unit3000 likes this.
  2. May 14, 2025 at 3:33 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Voss and Fragman[OP] like this.
  3. May 14, 2025 at 4:09 PM
    Fragman
    Hmmm. That might actually do it. It's in ABS, which will take the heat. I haven't tried printing in ABS as it is apparently a bear to work with without a heated enclosure. I'd have to print it on it's side and without the enclosure, it's likely it would not turn out well. This guy has already done it.
    I'm going to go ahead and order one. $18.75 shipped might seem a little pricey, but it's not worth the guys while to do it for less, I'm not having to faff around trying to get ABS to print at room temp cleanly and it could FINALLY be off my todo list on the Tundra!
    Thanks!
    G_unit3000[QUOTED] likes this.
  4. Jun 10, 2025 at 4:41 AM
    bretto24
    bretto24 New Member
    Brett
    2025 Silver Tundra Limited
    Fragman, curious if you did purchase and if so, did it work? I have a '25 with the power rear window in the same situation. Thanks for any information you may have!
  5. Jun 10, 2025 at 5:53 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Dashcam store sells a metal bracket that you truck into the weather stripping. Recommend getting the smaller size for less vibration. I've tried both..
    https://www.thedashcamstore.com/cus...ashcam-lenses/?searchid=0&search_query=Tundra
  6. Jun 10, 2025 at 6:28 AM
    bretto24
    bretto24 New Member
    Brett
  7. Jun 10, 2025 at 6:56 AM
    I don’t think that metal one will fit on 1st gen double cab in the same way.
    TacomaTRD4x402 likes this.
  8. Jun 10, 2025 at 8:40 AM
    TacomaTRD4x402
    Southern California
    The cam has adhesive but it also has holes to use hardware to mount. If I were to use screws I'd drill holes into the bracket. For now the adhesive is working fine for me.
  9. Jun 10, 2025 at 8:45 AM
    TacomaTRD4x402
    Southern California
    Ah that's a bummer.
    @Fragman So I just realized you said you have a double cab. This bracket is designed mainly for the crew ab models where the entire window rolls down. Can't you stick the camera to a section of your rear window that won't interfere with the sliding center window? Your entire rear window is 3 pieces, right? Or are you wanting it to be dead center?
  10. Jun 10, 2025 at 11:10 AM
    Fragman
    On a Gen 1, the Double Cab is the one with the full size doors and the 'slide up and down' window. You're thinking of the what they call the Access Cab. As to @bretto24 's question, I haven't gotten around to installing it yet! :)
  11. Jun 11, 2025 at 6:25 AM
    bretto24
    bretto24 New Member
    Brett
    @TacomaTRD4x402 The entire window goes down. There is no place to mount on the window as it totally disappears. Unless someone is disciplined enough (I'm not, LOL) to not power it all the way down. I, too would like to put the window down on days the temp allows but don't right now because of the cam.
  12. Jun 11, 2025 at 6:26 AM
    bretto24
    bretto24 New Member
    Brett
    @Fragman I'm counting on you to install so I know if I should buy, LOL. I'm waiting..... Hehe!
  13. Jun 23, 2025 at 11:47 AM
    bretto24
    bretto24 New Member
    Brett
    Hey Fragman, have you gotten around to installing your dash cam with the rear mount yet?
  14. Jun 23, 2025 at 11:50 AM
    Fragman
    No, but I intend to take next week off and if it's not a bazillion degrees, will be running it then as well as my Master tailgater camera feed.
  15. Jun 23, 2025 at 3:51 PM
    bretto24
    bretto24 New Member
    Brett
    Installing the cam is fairly easy and doesn't take that long. I highly recommend a dongal if the power wire hanging down from the cam bothers you (it bothers me, lol).
