  1. Jun 8, 2025 at 12:32 PM
    If you’re scraping your gas tank, you’ve got a lot of other things to worry about….
  2. Jun 8, 2025 at 12:33 PM
    Sounds like you guys need a community double cab. Polo and Casey loved my DC in the cinders
  3. Jun 8, 2025 at 12:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I mean... Yeah. I'll snap a shot of the scrapes sometime lol.
    And those were before I did the rock garden at Jambo this year.
  4. Jun 8, 2025 at 1:13 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I figured I'll make the kitchen capable of slangin' grub for the whole group and I won't have a problem finding a ride. I'd rather be running around with a camera/be a spotter anyway.
  5. Jun 8, 2025 at 1:51 PM
    shifty` Honey Bucket Houdini
    Found this ancient (vehicle?) antenna hiking up the side of Mt Battie today, in a shallow grave, hidden from daylight and the elements. Curious what it came off. Looks to be at least 50-60 years old.
    I saw something else on the ground, bent to pick it up, then saw the ball end of this a couple inches away. Pulled up only to realize the entire length of it was buried about 2-3” deep underground, horizontally. Had I not bent over I reckon it might’ve lived underground for eternity. I find the weirdest stuff out and about.
    Voss, FirstGenVol, BroHon and 2 others like this.
  6. Jun 8, 2025 at 2:18 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I was thinking about the shaded spot outside area B i wanna camp in.
  7. Jun 8, 2025 at 5:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah the spot just off the park road on the way to the tower, right?
    Sirfive[QUOTED] likes this.
  8. Jun 8, 2025 at 5:50 PM
    Azblue
    The Dirty T ( ^_^)_且
  9. Jun 9, 2025 at 7:40 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Opinions on PCV valve replacement? Never been done as far as I'm aware, I just clicked over 100K.
    Tripleconpanna and JakeJake like this.
  10. Jun 9, 2025 at 7:42 AM
    Dakillacore
    Georgia
    It's cheap and easy to replace. I say why not.
    Correct me if Im wrong, but if you remove and and shake it a bit you can tell if it's still good if it rattles.
  11. Jun 9, 2025 at 7:45 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I guess if I'm going to that length to shake it, I'm probably just going to replace it.
    bmf4069 and Dakillacore[QUOTED] like this.
  12. Jun 9, 2025 at 7:47 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Do it, super cheap maintenance and definitely wish I had changed mine out sooner at 185k; like yours, mine had never been touched. Since you have an '03, yours is threaded so it should be no problem, 22mm wrench and P/N 12204-50030.
  13. Jun 9, 2025 at 7:47 AM
    JakeJake
    2000 Tundra AC 4X4
    Id wager you're probably fine at 100k, but like DKK said it is a cheap and easy replacement. Go with the OEM part next time there's a sale going on.
    Mine was hella gunked at 275k. I was able to clean it well enough to keep it as a spare.
    bmf4069 and ATBAV8[QUOTED] like this.
  14. Jun 9, 2025 at 7:57 AM
    HD has these Army Green tool boxes they are peddling for fathers day. The kid in me really likes them.
    Voss, Jack McCarthy, bmf4069 and 4 others like this.
  15. Jun 9, 2025 at 8:04 AM
    des2mtn
    SW
    Tonto cover
    If you're in the market for a toolbox, this is the same one I got but in a different color. I like it a lot. Definitely recommend.
    Voss, Jack McCarthy, bmf4069 and 2 others like this.
  16. Jun 9, 2025 at 8:16 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Thanks to all who chimed in. Parts on order, will be replacing in the 1GT and the 5th Gen 4Runner. Just not a part I generally think about as a maintenance item. The 5th Gen has 185K on it, and it's never been changed. Pretty happy to own 2 pretty much bulletproof engines...
  17. Jun 9, 2025 at 9:18 AM
    Is that how you always store it?
    Voss, tpope, Jack McCarthy and 3 others like this.
  18. Jun 9, 2025 at 10:25 AM
    Yeah, I'm very confused by this picture. But I like it.
    Voss, Dakillacore and The Black Mamba like this.
  19. Jun 9, 2025 at 10:31 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Vertical storage. It's how you raise productivity.
  20. Jun 9, 2025 at 10:54 AM
    Actually, you should blow on it to makes sure it still acts as a one way valve.
  21. Jun 9, 2025 at 10:56 AM
    That’s gotta be a garage door that’s very hard to close if you need to weigh it down with a tool box.
    bmf4069 and des2mtn[QUOTED] like this.
  22. Jun 9, 2025 at 10:58 AM
    I’ve never had one go bad on me but I haven’t gone more than 100k on them.
    ATBAV8[QUOTED] likes this.
  23. Jun 9, 2025 at 12:24 PM
    You know you’re old when all the people in your work group have never heard of a PCMCIA card.
    It’s in the back of the lab sitting next to the Jaz drive. Don’t ask.
    bmf4069, shifty` and tpope like this.
  24. Jun 9, 2025 at 12:27 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    That's almost as funny as a 10 inch floppy disk..
  25. Jun 9, 2025 at 12:30 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Soo... has anyone had to clean out the space between the front fenders and the cab.. behind the door jamb? Mine is full of Fir needles. What's the best way to ensure I do a good job?
  26. Jun 9, 2025 at 12:30 PM
    Usually a reward system that matches the tasks perceived value, or even exceeds it.
    BroHon, bmf4069, des2mtn and 2 others like this.
  27. Jun 9, 2025 at 12:33 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I did that when I took the fender liner off to put the snorkel on. So, you can install a snorkel, or I'll just give your post a "like" when you post a done pic.
    BroHon, bmf4069 and KNABORES like this.
  28. Jun 9, 2025 at 12:33 PM
  29. Jun 9, 2025 at 12:43 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    @Jack McCarthy I'm gonna call BS on that sound bite... The ones we had at work were housed in a tyvek sleeve. Wonder why we had issues with static electricity.. Then we switched to Verbatim 8 inch. Jaz drives... Those were good times..
    Jack McCarthy likes this.
  30. Jun 9, 2025 at 1:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If you’re speaking of this area, I use hemostats or needle nose, especially in fall when leaves and debris is the worst. Once I remove as much as I can, I use water hose from top and also directly into.
    BroHon, KNABORES, bmf4069 and 2 others like this.
