  1. Jun 8, 2025 at 10:55 AM
    I just did out 5th gen this morning, ain’t any easier or harder
  2. Jun 8, 2025 at 11:11 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    I’m tired, maybe it’s the Lexus I have a hard time seeing. at any rate…. Having had Audis prior (super easy to read dipsticks) I always wondered why Toyota/ Lexus dip sticks weren’t as easy to see. Don’t get me wrong, I don’t miss my Audis ,,,, I no longer do disposable vehicles….lol
  3. Jun 8, 2025 at 2:54 PM
    Started doing the math after measuring the standard 265/70/16 tire and determined I need
    4x25”+52”+30”+15”+3” length of 2x12” wood for just one ramp = 200”x 2 ramps = 400”/12” per ft=33.33 ft of 2x12” plank.
    Figured I’d give these 30 year old made in USA ramps a shot first. Obviously using my Craftsman 4 ton jacks as a backup in case they collapse.
    I may clean them up first though.
    The Black Mamba, bmf4069 and BroHon like this.
  4. Jun 8, 2025 at 2:56 PM
    I’ve got a set of those. Havent failed me yet.
  5. Jun 8, 2025 at 3:08 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    I just used an identical pair and they did just fine. However, as a precaution I stacked a couple of 4x4's+ underneath just in case they decided to squat.
  6. Jun 8, 2025 at 3:49 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    A friend of mine has a series of wood ramps that allow him to get all four wheels of his truck up to two feet off the ground. They work, but in my opinion are a little sketchy, and it's a bit scary getting up onto them. Definitely requires a spotter. And they take up a lot of space. But they work. He helped me get my stripped front diff drain bolt out and I drove up on his setup. It was definitely nice being able to sit up under the truck.
    Jack McCarthy and oscardog86 like this.
  7. Jun 8, 2025 at 4:54 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Looks like they settled down about half inch. Will report back post allignment
  8. Jun 8, 2025 at 5:11 PM
    I like this idea. This might be the way.
  9. Jun 8, 2025 at 5:12 PM
    Damn, that’s gotta be up there if you can comfortably sit under the truck.
  10. Jun 8, 2025 at 5:51 PM
    MT-Tundra
    Montana
    Thought maybe I had a photo still, but I guess I deleted it over 30 days ago. But yeah, he has 2x8s fastened together, stacks of different lengths creating a ramp onto the highest level. I won't say the lowest part of my truck was over my head, but most places under the truck, I could sit up.
    oscardog86 and Jack McCarthy like this.
  11. Jun 8, 2025 at 6:25 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Doesnt everyone have a set of those yellow ramps?
  12. Jun 8, 2025 at 6:42 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Changed the transfer case, and front diff oil. They needed it. Royal purple was all I could find other than store brands locally of right weight. Then took it for a drive on hunt lease to kick in the 4x4 for about 5 miles.
    BroHon, oscardog86, bmf4069 and 2 others like this.
  13. Jun 8, 2025 at 6:47 PM
  14. Jun 8, 2025 at 9:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've got some plastic ramps from when I used to change the oil on my pop's Honda Civic. Pretty sure I got em at AutoZone.
    Looks just like these.
    I've never used em for any of my trucks. I have thought about using em for a flex treat, but decided my ditch was the better option. Both for ease of use and articulation.
    oscardog86 likes this.
  15. Jun 9, 2025 at 4:02 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I think you're referring to these...
    I tossed the stupid black plastic ones after I found the front of one cracked. These are actually made w/2x10s. They a little heavy but super solid and don't slide around at all :thumbsup:
    I believe in this configuration you'd get about 6" of lift and they are big enough to comfortably fit 35s on.
    100% trust these over plastic ramps!!!
  16. Jun 9, 2025 at 4:04 AM
  17. Jun 9, 2025 at 4:39 AM
    Awesome! It’s like the whole gang has them but never spoke of them.
    bmf4069[QUOTED] likes this.
  18. Jun 9, 2025 at 4:40 AM
    Beveled edges too! Nice.
  19. Jun 9, 2025 at 4:43 AM
    I never use them for my truck tbh. I use them for my wife’s JGC and the daughter’s Jeep Cherokee. I can just slide under my truck and do anything I need on a creeper there’s so much ground clearance.
    bmf4069, JakeJake, MooreKen and 3 others like this.
  20. Jun 9, 2025 at 4:46 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I like how you made sure to differentiate the Jeep Cherokee from the Jeep Grand Cherokee on the Toyota Tundra forum.
    Like they ain't both Cherokees to us. :p
  21. Jun 9, 2025 at 4:46 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I picked these up a long time ago for changing the oil on the Civic, I don't think I've ever had the Tundy up on them. Use for Ferd-Edge oil changes though.
    For you in the SunBelt, that red thing is a Snow Blower :rofl:
    Garage still in a state of disarray. Lumber yard run today to get materials for shop/shelving build (hopefully)
  22. Jun 9, 2025 at 4:52 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    snow blowers are probably so much fun.
  23. Jun 9, 2025 at 5:01 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Tote in the background: Not an OG, but this certifies I am indeed a cult member I think.:rofl:
    The truck came with a big ass bin of parts. I had no idea what I was in for with this journey back then. Glad I found ya'll :fistbump:
  24. Jun 9, 2025 at 5:36 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I wish i had a box of bearing dust.
    BroHon[QUOTED] likes this.
  25. Jun 9, 2025 at 5:42 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That's a movotech exclusive
    bmf4069, Sirfive[QUOTED] and BroHon like this.
  26. Jun 9, 2025 at 5:46 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  27. Jun 9, 2025 at 6:36 AM
    MT-Tundra
    Montana
    Yep, very similar! Yours are a bit nicer with the angled edges, but very much the same idea. He also has a vertical stack for the back tires. I drove up on the one like you show, with the front tires, then we used a floor jack under the rear diff to lift back up and set the other two stacks under the back tires. And yeah I'll bet his are also 2x10.
  28. Jun 9, 2025 at 6:38 AM
    MT-Tundra
    Montana
    I've seen the older version of these on FB Marketplace for pretty cheap...I was hesitant, not knowing the quality or how previous owners had used them. I wasn't sure I trusted them. But it was a good deal.
  29. Jun 9, 2025 at 9:14 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    also all my steering wheel radio controls seems to be going kaput. So gotta add that to the list.
  30. Jun 9, 2025 at 12:26 PM
    MT-Tundra
    Montana
    Found it. Not quite as high as I remember, but 100% improvement over ground level.
