TRD Grill is too janky for Diode Dynamics light bar?
Discussion in '3rd Gen Tundras (2022+)' started by jeffcoseo, Sep 4, 2024.
  1. Sep 4, 2024 at 12:38 PM
    jeffcoseo
    jeffcoseo [OP] New Member
    Jeff
    I installed the TRD Grill on my SR5. Seemed easy. I don't have a camera in that little hole - but that's fine. I installed the Diode Dynamics Light Bar and bracket. Seems like a nice piece.
    Holy cow. I can't drive on a country road with that light on. The grill has so much flex - the light is flashing up and down off the road. You can see the beam of light jump and shake with every bump. Sky, road, sky road, sky, road.
    So... I hop out... and tap on the grill. No Shit. That plastic grill has zero support and just vibrates and wiggles and dances.
    Am i the only one?
    I guess I can build a strut that comes out from the Radiator Flappy Thing and supports the grill where the Camera goes...?
  2. Sep 4, 2024 at 12:47 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Did you install the upper and lower brackets as well, or just the side brackets? Mine has some flex but definitely not jumping all around like described
  3. Sep 4, 2024 at 12:49 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Its not the grille's fault...its that cheap pos kit DD sells without a proper support bracket. My baja designs light bar is SOLID.
    Did your kit from with the upper and lower brackets or just the light bar surround?
    Pittsy likes this.
  4. Sep 4, 2024 at 12:52 PM
    jeffcoseo
    Jeff
    I guess I don't know... What brackets? I feel like I'm missing something.
  5. Sep 4, 2024 at 12:53 PM
    eddiefromcali
    Eddie
    100% Stock
    oddhours likes this.
  6. Sep 4, 2024 at 1:04 PM
    jeffcoseo
    Jeff
    I'll have to crawl under there and look!
    Thank you for the photo!!
    I installed the grill and light bar a year ago. I haven't used it much. It was so annoying last weekend. Not worth having.
    eddiefromcali likes this.
  7. Sep 4, 2024 at 1:17 PM
    eddiefromcali
    Eddie
    100% Stock
    I'll add one more thing...these brackets do not take the weight off the grille...they simply help distribute it. Those mounting points they use are for the grill shutters which are directly attached to the grille. Baja Designs and Westcott both use similar brackets but they attach to the truck itself and thus do not rely on the grille to support the weight. DD just went the cheap route and provided a janky little bracket. You bought the wrong kit :)
    And no need to get under the truck...you can take a look from above
  8. Sep 4, 2024 at 1:59 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    the brackets were included in my kit I got from Black Friday and were somewhat recent to that sale to be included. If you installed in earlier part of year, chances are you may not have the updated brackets.
    To both Eddie and my point earlier, you still have some level of light bounce due to where those brackets mount to. An actual frame mount would have been much better to eliminate it but you get what you pay for and all.
  9. Sep 4, 2024 at 2:07 PM
    eddiefromcali
    Eddie
    100% Stock
    exactly...theres a reason why Jeff's brackets alone are $200+. I actually think this is a superior mounting solution than BD's. Jeff mentioned that they noticed grilles fracturing when submitting them to continuous vibration w/o a bracket and thats why he designed this setup. Everyone else followed suit to match their price point.
  10. Sep 4, 2024 at 2:20 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Older kits didn’t come with them. Newer ones do. If yours didn’t email them and they’ll send it out. Made a big difference.
  11. Sep 4, 2024 at 6:49 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Same issue with my Heritic mount. Reached out to them and they sent out free of charge a new updated mount.
    ImAwful likes this.
  12. Sep 5, 2024 at 11:48 AM
    jeffcoseo
    Jeff
    Wow. You guys are Gurus.
    No - my kit did not come with any additional brackets. I bought the kit from Diode Dynamics over a year ago.
    Is the Westcott Kit superior? Would the Westcott mount fit my current DD Light Bar? Maybe that's my solution...
  13. Sep 5, 2024 at 11:57 AM
    Ipaddick
    Ipaddick New Member
    Canada
    You can email diode dynamics and they’ll send their new brackets for free
  14. Sep 5, 2024 at 12:29 PM
    eddiefromcali
    Eddie
    100% Stock
    Westcott kit is the best one out there and fits 20" bars...notice how it has the little < > wings on the ends of the opening to blend into the grille...very nice little touch. I'd call them and ask for the dimensions and compare to your DD bar
    https://westcottdesigns.net/product...light-bar-bracket-kit/?attribute_model=Tundra
  15. Sep 5, 2024 at 2:55 PM
    Black widow TRD
    Manuel
    Ahh yes those wings!! Making this the flyest of all mounts!
    My Heretic does not those wings… :monocle:
  16. Jan 28, 2025 at 12:50 PM
    gesekee19
    gesekee19 New Member
    do you have a picture of how the two mounts install? Just installed mine but couldn’t figure out how to install the included vertical mounts since Heretic did not provide any instructions.
  17. Jun 3, 2025 at 10:47 PM
    spliffgates
    spliffgates New Member
    2022 Magnetic Grey SR5 Tundra 4x4
    How have you liked your heretic light bar mount? Considering using that one but want to make sure it doesn’t have the vibration issue.
  18. Jun 4, 2025 at 5:43 AM
    LB-1889
    LB-1889 New Member
    I have the Wescott kit pretty solid. There where a few angles that were off when mounting the brackets that I had to correct. Probably the worst part of the kit was the upper bracket interferes with the TRD marker lights, needed to trim for clearance.
    TRD L Power and sudobash like this.
  19. Jun 4, 2025 at 8:41 AM
    eddiefromcali
    Eddie
    100% Stock
    Are those OEM markers?
    sudobash likes this.
  20. Jun 4, 2025 at 8:48 AM
    LB-1889
    LB-1889 New Member
    Yes they are.
  21. Jun 5, 2025 at 4:32 AM
    gesekee19
    love the heretic. Much brighter than diode, oem or Baja. After speaking with heretic, I was able to mount up the bracket correctly and now it’s very stable
    spliffgates[QUOTED] likes this.
  22. Jun 7, 2025 at 6:42 AM
    Manutd818
    Manutd818 New Member
    2024 Tundra Limited Trd off-road
    Damn still have to install my Baja lights for the fog lights. I don’t feel like taking off the bumper lol.
  23. Jun 7, 2025 at 10:42 AM
    TRD L Power
    TRD L Power New Member
    2023 SR5 XP TRD Off-Road Army Green
    I will say, that even with the DD mounting brackets, there will still be some jitter on the road over bumps. It isn't brutal, but it is noticeable. I'm sure the BD or WD brackets are much sturdier.
  24. Jun 7, 2025 at 9:52 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    All you have to do for fogs is pull once piece of plastic trim off, not too hard other than avoiding breaking the clips.
  25. Jun 7, 2025 at 11:27 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    You can say that about any grill on new vehicles.
    Gone are the days of the chrome steel bumpers no doubt.
    But as has been shown the aftermarket people will find a way.
    Of course it'll cost ya....
  26. Jun 7, 2025 at 11:55 PM
    Manutd818
    Oh no way why did I think otherwise. Gonna get to it tomorrow.
    chrisgibbs707[QUOTED] likes this.
  27. Jun 8, 2025 at 12:44 AM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
  28. Jun 8, 2025 at 7:18 PM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    anyone have a part number for the OEM marker light assembly?
  29. Jun 9, 2025 at 6:33 AM
    LB-1889
    LB-1889 New Member
    PT358-34220-AB
    ghunter321[QUOTED] likes this.
