General Supercharger Thread
  1. Jun 8, 2025 at 7:39 PM
    blenton
    blenton New Member
    Any chance your starter simply decided to die at the same time - as coincidental as it sounds? I know it's a bit of a chore, but you can pull the starter and bench test it with a battery. Or at least use the test probe at the starter to see if it's getting voltage. The voltage drop you are seeing associated with the high draw is normal-ish when starting a big motor. I seem to recall seeing around 11v when starting, but I think anything over 10 is still considered a healthy battery. I had one jump to around 8v when starting, indicating a bad cell. Anyways, the voltage drop would indicate a load on the battery, which would happen whether or not the starter was good, if that makes sense. Should rule out some wiring issues. I'd look at the starter itself. I've seen them jamb up and produce the same result - either a click or no crank situation but the battery voltage still sags.
    e30cabrio[QUOTED], Wynnded and Mdl like this.
  2. Jun 8, 2025 at 7:56 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Yep, that's the plan now. No sure if I will order the AirDesign vents or adapt bigger vents. Added a longer vent using a photo editor to have an idea and I love how it looks....
    mustang67408, armyoffoo and Mdl like this.
  3. Jun 8, 2025 at 8:36 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I finally installed my engine oil adapter, remote filter and oil cooler. I had to unwrap and pull the stock oil pressure sensor wire further back so it would plug into the sensor's new location, then tape it back up. I need to make 4 short hoses and fill oil, then my oil cooler project will finally be done.
    ARES35, nasher75, reywcms and 9 others like this.
  4. Jun 8, 2025 at 8:36 PM
    blenton
    blenton New Member
    @e30cabrio - just thought about one more thing. Try removing the serpentine belt and see if it cranks.
    I had a couple of buddies in high school that happened upon an old corvette with a bad motor in their neighbors barn. Neighbor sold it to them cheap on account of the bad motor that wouldn’t turn over. They looked it over with some help from a mechanic and found the alternator to be seized up. $100 later and they had a running, driving corvette.
  5. Jun 9, 2025 at 6:31 AM
    nags
    nags New Member
    Had mine over 120 a few times as well with plenty in the tank when I let off.
  6. Jun 9, 2025 at 6:32 AM
    nags
    nags New Member
    My Harrop definitely came with a pump.
    nobodyintexas likes this.
  7. Jun 9, 2025 at 6:39 AM
    nags
    nags New Member
    @reywcms you forgot to grab my truck on the way to Snivs.
  8. Jun 9, 2025 at 6:43 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Good news! It turns!!
    I'm pretty sure I fried the new starter being an idiot, trying to start it. It's already 85 @ 6:39am, I'm too old to fuck with the starter so will find someone to come do it after making sure it's dead and getting another from Toyota.
    Tips on getting around everything that's in the way to get power directly to the solenoid greatly appreciated. (I looked while I was under there, can barely see the back of the solenoid)
    This is why I replaced it when the motor was out.
    I'm just happy the motor isn't dead, honey I have to get a new motor wasn't a conversation I was looking forward to.
    Wynnded, armyoffoo, bflooks and 6 others like this.
  9. Jun 9, 2025 at 7:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    HA- @snivilous is ready for yours when you are!
  10. Jun 9, 2025 at 7:26 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I had issues in 87 degree weather yesterday! Good luck with the starter replacement.
  11. Jun 9, 2025 at 7:42 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Shit that reminds me I forgot to pick up my friends 4.6 this weekend :mad: I was too distracted with the bus we bought :rofl:
    ssmokedz, ZPhilip, Wynnded and 10 others like this.
  12. Jun 9, 2025 at 7:45 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    5.7 SC swap?:rofl::rofl::rofl:
  13. Jun 9, 2025 at 7:47 AM
    snivilous
    SW UT
    Maybe it could exceed 50mph up a hill, or 65mph on the downhill :rolleyes:
  14. Jun 9, 2025 at 7:49 AM
    centex
    centex New Member
    Had a buddy in college buy a bus for his band. They will fit through certain mcdonald's drive thru's and no one questions a bus stopped in front of kroger with the stop sign out.
  15. Jun 9, 2025 at 7:54 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    New party/race headquarters bus?:D
  16. Jun 9, 2025 at 8:11 AM
    e30cabrio
    Wasn't there a move where diplomats kids were kidnapped in a fake bus?
    mustang67408 and HulkSmurf14 like this.
  17. Jun 9, 2025 at 8:12 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
  18. Jun 9, 2025 at 8:17 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Bought the bus to haul all the parts I have lol
    Wynnded, HulkSmurf14, Mdl and 3 others like this.
  19. Jun 9, 2025 at 8:39 AM
    e30cabrio
    Is there a starter fuse in the fusebox out set of fusible links? It sucks to remove but is way easier than the starter.
    HulkSmurf14 likes this.
  20. Jun 9, 2025 at 8:55 AM
    bflooks
    bflooks New Member
    Metrowest MA
    The "not so" short bus?
    Mdl and HulkSmurf14 like this.
  21. Jun 9, 2025 at 9:08 AM
    e30cabrio
    Google AI says yes.
    Guess I'm pulling the fuse box again.
  22. Jun 9, 2025 at 9:09 AM
    snivilous
    SW UT
    The short buses are expensive! The 40 footer was only $3500 :rofl: and if you're buying a bus, buy a proper big boi bus!
  23. Jun 9, 2025 at 9:21 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Didn't you have an issue with the fusible link last year or two?
  24. Jun 9, 2025 at 9:26 AM
    e30cabrio
    Yes, another self inflicted injury, Land Cruiser HVAC fan was reverse polarity, that is how I became a Fusible master tech.
    It's now a simple 10 minute job for me & the OEM part is sub 60 bucks. (ordered)
    Mdl[QUOTED] and HulkSmurf14 like this.
  25. Jun 9, 2025 at 9:30 AM
    mustang67408
    Victor
    If I'm not mistaken, this fuse link blocks come out thru the bottom of the fuse box because they are bolted in.
    It's been a while since I've replace one.
    I think it's harder than doing the starter
    koditten, M3Tundra-JK and e30cabrio like this.
  26. Jun 9, 2025 at 9:34 AM
    e30cabrio
    Yup you have to lift up the middle of the box to access the bolts which look similar but one is 10mm and another is 8. Why Toyota??
    I had to do it several times. It's easy now, like r&ring BMW motors the 20th time in under a year.
  27. Jun 9, 2025 at 9:36 AM
    mustang67408
    Victor
    WHY TOYOTA??? I ask myself that everyday, since we now have GM engineers working for us.....
  28. Jun 9, 2025 at 10:52 AM
    e30cabrio
    Pulled it out, none appear blown, as best I can tell there is continuity to all. I'll have the new one tomorrow, starter will ship whenever.
    Why are the biggest wires 8mm, the rest 10??
  29. Jun 9, 2025 at 11:08 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Supposed to pick up the Truck tomorrow....
    Man is it gonna be Nice to be Supercharged again!!!
  30. Jun 9, 2025 at 2:42 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Tell me you are boosting that thing!
