Identifying rear axle
Discussion in '1st Gen Tundras (2000-2006)' started by Bringtobear, Jun 8, 2025 at 9:23 AM.
  1. Jun 8, 2025 at 9:23 AM
    Bringtobear
    Bringtobear [OP] New Member
    Tuesday
    Leo
    2001 Red Tundra 4.7l SR5
    Uncertain
    Hi guys. First post here. I need a new axle shaft as mine is likely bent, the runout measured on the outside of the axle nut is ~10x greater than specification at some points.
    Can someone help identify whether this rear axle is from an access cab? The vin shows that it was an access cab but I saw on another forum post that only double cabs have recessed inner seals. Also, the pumpkin has 3.90 scratched on it if that helps in identification. The truck is a 2001 4.7l 4x2 Tundra.
  2. Jun 8, 2025 at 9:33 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    That's the correct axle. I can tell by the way it is.
    bmf4069, Sirfive and KNABORES like this.
  3. Jun 8, 2025 at 9:52 AM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    Thanks a lot, I appreciate the quick response. I also measured from flange to flange/across the backing plates and came up with approx 59" which I believe is the correct measurement for an axle from an access cab. So now the question is, can I go to the junkyard and replace it with an driver's side axle shaft from say, a 1st gen v6 access cab tundra? What are the limitations?
  4. Jun 8, 2025 at 10:22 AM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    Also, does abs increase the length of the shaft? Or would I be fine with getting a non-abs part and just installing the tone ring and retainer?
    Thanks.
  5. Jun 8, 2025 at 10:32 AM
    JakeJake
    2000 Tundra AC 4X4
    The v6 should run the same axle, maybe a different pinion flange. @The Black Mamba is the resident expert there
    As for the tone ring I wouldn't bother trying to locate and install that correctly, just find an oem used unit. @bmf4069 can tell you some stories :rofl:
    bmf4069 likes this.
  6. Jun 8, 2025 at 11:30 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Where are you measuring runout? There is no rear axle nut.
    JakeJake and KNABORES like this.
  7. Jun 8, 2025 at 11:32 AM
    That one greasy third member. How’s the axle vent looking?
    JakeJake likes this.
  8. Jun 8, 2025 at 2:24 PM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    and plsatic piece
    I meant "axle shaft deviation" as specified in the fsm.
  9. Jun 8, 2025 at 2:27 PM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    Thanks for the tips. So to reiterate, the ABS axle is the same length as the non-abs, all else equal?
  10. Jun 8, 2025 at 2:29 PM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    I checked it and the spring was nice and supple; the plastic piece was also nice and undamaged. I think the gasket is just old. The rear axle shaft was leaking gear oil as well but that occurred after the differential was leaking for quite some time. I believe the retainer ring on the tone ring was installed too far in so that the bevel on it was riding right on the seal, leading to premature wear.
  11. Jun 8, 2025 at 2:39 PM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    I am guessing however, that when seal leaks it doesn't immediately cause gear oil to leak onto the back side of the wheel (which is how I noticed it). Hence the two leaks could have occurred close in time. I may just replace the valve to be safe. I also checked that there is a clear passage from inside the differential to the valve by spraying a little brake clean inside and watching it drip out after I drained the diff.
  12. Jun 8, 2025 at 3:01 PM
    Bringtobear
    Tuesday
    Leo
    Uncertain
    Also, my spline count for the rear shafts are 30... does anyone know why a lot of replacement kits are 32?
