Ironman Raid front bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by mundra, Nov 20, 2024.
  1. May 6, 2025 at 5:42 PM
    #91
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I drilled 1/2 inch holes in the top plate and then put a stainless bolt through it with loctite and a lock washer and fender washer. There is enough clearance to pull the 1 inch long bolt out after you loosen it.
  2. May 6, 2025 at 5:44 PM
    #92
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    There is some wiggle but not much. its 1/4 inch cold rolled steel so its pretty solid. I haven't taken it out to drive it yet. I thought about welding a few tabs on the front and putting a rivnut in to the tube steel of the bumper to attach with a bolt. Still an option if they move too much.
  3. May 6, 2025 at 7:07 PM
    #93
    Cthulhu
    Thanks! PLEASE refresh my memory. Don’t you have to remove the top side plates first to access the nuts under the center top plate, since the center plate nuts are inaccessible once the bumper is mounted? I seem to remember, after mounting the bumper, having to install the center plate first (actually using duct tape to hold the nuts in place while screwing down the bolts), then installing the side plates.
  4. May 7, 2025 at 8:28 AM
    #94
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    When I installed my bumper I didnt remove any of the plates. I left them installed and bolted up the bumper. With this design you can reach the bolts holding the lighting cross bar with an 12 inch long extension just fine.
  5. May 10, 2025 at 10:19 AM
    #95
    SanDiegoSlovak
    SanDiegoSlovak Learning Thru Mods
    San Diego, CA
    2008 Double Cab SR5 4x4
    3" lift, 35" tires, hi-clearance bumpers + more!
    So I finally got my Ironman Frontier winch and am trying to decide on where to install the winch control box. @APalmTree or any other 07-13 owners with this bumper, where did you install your winch control box? I think the 14-21 guys can install it on top of the winch itself but this older model doesn't have space.
    APalmTree likes this.
  6. May 10, 2025 at 6:41 PM
    #96
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I got the HF Badlands Apex and the control box is in place on the top of the winch. Not sure what the space looks like for Ironman’s in house winch.
  7. Jun 7, 2025 at 9:51 AM
    #97
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Little update, the lights have some wiggle (minimal) while driving but about a month or so they are still holding strong. Super happy with the design and how it turned out. Let me know if you guys want one!
    Travo60 likes this.
  8. Jun 8, 2025 at 1:27 PM
    #98
    ke4640
    ke4640 New Member
    Today
    I've BEEN TRYING, to find pics of someone doing this with their Ironman. I've been on the fence of getting one. Anyway, you can post some more overall pics of the truck with the setup, a little further back. It would be much appreciated!
