  1. Jun 6, 2025 at 2:08 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    I was hoping I didn't have to resort to an impact to save the money. 1/2" drive is next .
  2. Jun 6, 2025 at 2:17 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Mapp gas HEAT. If you want to break a bolt off going up to 1/2" drive is the way. unsolicited opinion stated. :anonymous: I wish you the best though ;)
  3. Jun 6, 2025 at 2:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Approved
  4. Jun 6, 2025 at 3:00 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    I recently changed out the rubber bushing on the right side of the steering rack. The impact had no effect. The 1/2" bar had no effect so I added a 3 foot extension to the bar and even then it only budged when I put all of my body weight (230lbs) on it. After a couple of 1 inch movements it was finally loose enough for the impact to finish the job. Whatever the factory uses to tighten these bolts/nuts it ain't a torque wrench no matter what their specs say. Get yourself a 3 foot piece of pipe to slide onto the end of the bar for more leverage.
    DarkMint[QUOTED] likes this.
  5. Jun 6, 2025 at 5:38 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    This was my co-worker, not an actual K9, for anyone confused :cool:
  6. Jun 6, 2025 at 5:40 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :rofl: Just following reflection S.O.P. Sir :hattip:
  7. Jun 6, 2025 at 5:40 PM
    No one was confused…..
  8. Jun 6, 2025 at 5:46 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Is polo my coworker?
    Asked him, polo’s my boss.
  9. Jun 7, 2025 at 7:18 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Just got my rack and pinion replaced (ordered oem from toyota) realized I probably forgot the bushings. Driver side is definitely cracked here. Passenger doesnt look as bad. I should obviously get these replaced right? Could they also be potentially contributing to steering wheel shake/wobble?
    Voss likes this.
  10. Jun 7, 2025 at 7:56 AM
    Those don’t look bad to me. The only “crack” I see in the bushing is the split that lets you open the bushing to place in over the sway bar during install.
  11. Jun 7, 2025 at 8:38 AM
    Dblock500
    DMV
    Ah ok, yeah that's what i was talking about in the 1st picture. Well I'll probably have a lot of things to track down then, another balance even though I just got one--could be that the place that did my brake upgrade knocked some weights off. Could be UCA bushings
    KNABORES[QUOTED] likes this.
  12. Jun 7, 2025 at 8:55 AM
    shifty` Honey Bucket Houdini
    I bought those swaybar bushings for my truck. Then deleted my swaybar before installing them. I was replacing mine just because they were firm. Yours don’t look bad at all.
    Dblock500 and FrenchToasty like this.
  13. Jun 7, 2025 at 9:46 AM
    Dblock500
    DMV
    Ok good to know. I'm leaning towards just pulling the trigger on OEM new UCA and putting new pre-assembled 4600 w/coilovers. (I did read the mega thread about it and fine with just having stock rode feel, no plan on lift anytime soon, and the cheaper option)
  14. Jun 7, 2025 at 10:49 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yeah, I was definitely confused about a steering rack post with sway bar bushing pics
    BroHon and FrenchToasty like this.
  15. Jun 7, 2025 at 11:40 AM
    LOF today, did the dip stick mod, it’s still a pain in the ass to see the level with clean oil
  16. Jun 7, 2025 at 11:51 AM
    Dblock500
    DMV
    Yeah i confused myself lol, i need to get under and check the actual steering rack bushings
    FrenchToasty and KNABORES like this.
  17. Jun 7, 2025 at 12:06 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Lol. it aint arco. Wonder if adding graphite to my mobile 1 will hurt anything, it’ll at least make it dark enough to see.
    lol, $140 oil change.
  18. Jun 7, 2025 at 12:07 PM
    Ooo European!
  19. Jun 7, 2025 at 1:38 PM
    I’m still trying to understand how it’s an issue. When I look at my unmodified dipstick, I just turn the dipstick to see how the oil level glistens in the sun. It’s either readable on the front or back depending upon how you pull it out. It’s always slightly golden when new.
  20. Jun 7, 2025 at 1:50 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I can see the layer better if i use a flashlight.
    for weight reduction i might drill 5-6 1/16” holes & hope surface tension helps me read it at a glance. No squinting necessary. Might have some golden varnish on the dipstick. Adding a couple glugs of MMO @ 4k miles helps to read it @ 5k.
    FrenchToasty and Jack McCarthy like this.
  21. Jun 7, 2025 at 2:19 PM
    You can’t read that?! I know how to solve this problem….
  22. Jun 7, 2025 at 3:10 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Today I replaced the intermediate carrier bearing. What a PITA! The bolt heads were rusted too much for a socket to grab hold and after several attempts at alternate methods I bit the bullet and drilled the bolts out. Laying on my back trying to apply pressure while attempting to drill vertically wore me out, especially with all the hot shavings falling on my hands. Next up is the rear u-joint then, theoretically, I'm done underneath.
  23. Jun 7, 2025 at 3:13 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    PA has to be the ‘expert difficulty’ life server, right? Yall get eff’d from all directions.
  24. Jun 7, 2025 at 4:44 PM
    Neo
    Neo New Member
    Alabama
    Don't you have to swap all your torque wrenches for impact wrenches to become ASE certified? ;)
    ToyotaDude likes this.
  25. Jun 7, 2025 at 9:24 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Did another change on rear differential oil.
    Still grungy. Do another in about 3K miles.
    Started doing slow flush on the power steering fluid. Draining reservoir, filling, driving and repeat.
  26. Jun 7, 2025 at 11:25 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
  27. Jun 8, 2025 at 6:04 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Can't remember if it was you that said you didn't have a smartphone, but if you have a way to take some pics and post them up we'd love to see the truck doing truck stuff.
    KNABORES likes this.
  28. Jun 8, 2025 at 9:33 AM
    Redoak
    Redoak New Member
    Dave
    none
    I plan to a full clean, and flush of reservoir soon.
    Can’t think where my other floor jack went, to raise both sides, and just want to start getting some of that old thin fluid out.
    Don’t know what they used but was as thin as water. Have to actually pump it out now compared to just getting it started and it siphoned out on its own in beginning.
    Steering is getting lot better.
  29. Jun 8, 2025 at 10:06 AM
    ToyotaDude
    ToyotaDude Member
    Do you raise the front in the center with a single jack then block each side with a jack stand, or jack each side frame rail?
    Thanks to @shifty` for some guidance that might help here showing front cross member from FSM.
    https://www.tundras.com/threads/fir...-fsm-om-and-maybe-others.124063/#post-3176718
  30. Jun 8, 2025 at 10:52 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    100%. Take it to the sunlight when the oil is new. If you think this dipstick is hard, you would shit trying to read the 5th Gen 4Runner dipstick.
