Frozen End Link at the Stabilizer Bar
Discussion in '1st Gen Tundras (2000-2006)' started by TnPlowboy, Jun 6, 2025.
  1. Jun 6, 2025 at 6:46 AM
    TnPlowboy
    TnPlowboy [OP] New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    I have a frozen End Link where it passes thru the Stabilizer Bar. I removed the 14 mm top nut and the 17 mm nut that attaches to the LCA, no prob. But the darn thing is just hanging there. Hard to believe the top and bottom washers are melded to the end link. Is this going to have to be cut off or has someone found a better solution?
  2. Jun 6, 2025 at 6:49 AM
    I’m confused. First the link looks bent. But are you saying the washer is fused to the threaded shaft? If so, get a deep well socket, put it open end facing down on top of the washer. BFH and whack the fuck outta it. That washer should let go. If try to find a socket just large enough to fit around the shaft, 10mm-12mm deep well should do it. But may also have luck with one just large enough to fit the perimeter of the washer.
    TnPlowboy[OP] likes this.
  3. Jun 6, 2025 at 6:53 AM
    TnPlowboy
    It does look slightly bent at the end but yes the washer is frozen to the shaft. Will try your suggestion in a minute
  4. Jun 6, 2025 at 6:57 AM
    It should work, without causing any damage to the washer. Start with light taps and work your way up, so you don’t mushroom the ratchet-side of your socket. I’ve got a few sockets mushroomed in the box from times I had to go ham.
    Sometimes running a nut down the shaft with an impact will also break the bond. But you can blow out the bushing too. Although your bushings there look pretty tired. I’d use a nut you don’t care about that uses same threading.
    TnPlowboy[QUOTED][OP] likes this.
  5. Jun 6, 2025 at 7:58 AM
    Did you unbolt the other side.
  6. Jun 6, 2025 at 8:41 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I second BFH
    TnPlowboy[OP] and w666 like this.
