Front Seats 2017 Platinum
Discussion in '2.5 Gen Tundras (2014-2021)' started by RaginCajuns, Oct 24, 2017.
  1. Oct 24, 2017 at 4:39 PM
    RaginCajuns
    RaginCajuns [OP] New Member
    Prairieville, LA
    2017 Super White Tundra Platinum 4X4
    Is there a way I can keep my drivers seat and steering wheel from moving all the back every time I stop the truck and remove the key / re inset the key. I would just like for my seat to stay in the position that I have set.
  2. Oct 24, 2017 at 5:42 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    They do it as a convenience for driver to get in and out.... more room
    T-Rex266 likes this.
  3. Oct 24, 2017 at 5:49 PM
    moviepro314
    moviepro314 New Member
    Iowa
    2017 Tundra Platinum
    Line-x Premium Spay-on bed liner, Truxedo Lo Pro Roll-up Tonneau Cover, Dual Swing Cases from Undercover, Pop & Lock Power Tailgate Lock, BottlePro 2
    I believe the dealership can disable this feature.
  4. Oct 25, 2017 at 3:01 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    D.I.Y. with Techstream.
    ChucklesToy likes this.
  5. Oct 25, 2017 at 4:15 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    For my 2013 there were a huge list of settings in the manual in which you could change via the dash display (where it should mpg, miles to empty, etc.). I must have disabled the seat movement because mine doesn't move but wasn't able to disable the steering wheel movement.
    The wheel movement doesn't bother me too much except for when I use remote start - when running and you put the key in, the wheel doesn't move and I have to remember to hit my preset to move it into place. Annoying when you forget and start driving away because the preset only works when in park.
    I just wonder how many cycles that motor has in it before it goes out and needs an expensive replacement...
  6. Oct 25, 2017 at 4:49 AM
    RaginCajuns
    Prairieville, LA
    Is this an app or link?
  7. Oct 25, 2017 at 4:57 AM
    RaginCajuns
    Prairieville, LA
    I do not have this setting for the seat in my dash display. I guess Toyota changed this feature in with the GEN 3 in 2014.
  8. Oct 25, 2017 at 5:44 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Toyota can disable it. It’s callled easy entry access. I turned mine off. The seat and steering wheel is programmed independently
  9. Oct 25, 2017 at 6:55 AM
    nodak67
    nodak67 New Member
    JR
    guess I'm going to have to update my techstream on the laptop again, ugh. will have to test to see if it even shows up on my current techstream :)
  10. Oct 25, 2017 at 10:39 AM
    AxelsHumanDad
    2015 CM Platinum
    A program you load on a laptop. Plug into your OBD port and configure all sorts of settings to your liking. Techstream is in the wild all over da interswebs. Or you can pay Toyota lots of dollars to change settings for you.
    I disabled my seat movement but left the steering wheel away enabled.
