Falken Wildpeak AT4W - C or E rated Tires?
Discussion in 'Wheels & Tires' started by rchaney99, May 19, 2025.
  1. May 19, 2025 at 8:10 PM
    rchaney99
    rchaney99 [OP] New Member
    2019 Toyota Tundra TRD
    Im in the market for new tires. I see the Wilkpeak AT4W is offered in C (SL)load or E load range now. What do you recommend? I tow a small trailer thats 5k lbs but not far or very often.
    2019 Tundra TRD
  2. May 19, 2025 at 8:32 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    I replaced a set of AT3W in load range E with AT4W in C. Really mellowed out the small road imperfections, making the ride much better. Recommend the C.
    sudobash likes this.
  3. May 19, 2025 at 8:37 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I personally really like the durability of E-rated tires on these heavy trucks. They make the ride a little firm as well, which I appreciate.
    Tundrav82019 and MadMaxCanon like this.
  4. May 19, 2025 at 8:44 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I don't tow but I haul and offroad with extra weight on the truck and the E rated tires take an absolute beating. I've gotten so many cuts that I feel would have popped a lower load tire. I vote E.
  5. May 19, 2025 at 8:46 PM
    rchaney99
    I do see they dont make a C rated in 275/70R18 size though. I was thinking of getting the bigger size - so I may have to go E rated.
    MadMaxCanon likes this.
  6. May 19, 2025 at 9:10 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    C rated will be best for ride comfort but may wear a little faster.
    I was looking at the 35x11.5r18 wildpeaks that are C rated. They went from $365 to over $400 overnight earlier this month. Screw that.
    I then got Hankook 285 75 18 tires that E rated for $260. I'm cheap like that.
    Tundrav82019 likes this.
  7. May 19, 2025 at 10:33 PM
    Tundrav82019
    Tundrav82019 I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    I recognize those AGP wheels! How you liking them? Any issue with sling on the side of truck or balance issues?
  8. May 19, 2025 at 10:37 PM
    Tundrav82019
    Leo
    C rated is more plush feeling and better ride comfort. E rated will be stiffer, but more capable for tow feel and side wall protection. I personally have Falkens Wildpeaks AT4Ws in E range, love them. I like a stiffer ride, but I also tow more. I like that they can handle more pressure and range for PSI.
    Also, if you want triple side wall, their Duraspec, you need to specify it. E range doesn’t automatically come with it, most are 2 ply side walls otherwise. Each e range tire I believe can handle 3,600 pounds each! Very capable tire. 60k warranty and 18/32 tread. I vote E rated. It’s a super quiet tire, I don’t ever hear it. C load range is 65 k warranty and not much more for the E rated one. If you off road once and it saves your tire, it’s worth it to me.
    I would make sure to get a cooler too. Genuine transmission cooler is what I installed.
    here is a pic of my wheels
  9. May 19, 2025 at 10:50 PM
    Gtboosted
    Los Angeles
    No balancing issues. I have driven 500 miles with no vibration.
    As far as slinging...I had 0 offset wheels before and it was annoying keeping the truck clean.
    I bought Ark Mud guards for them but was lazy installing them. I barely got these wheels last week and a couple days later I installed the mud guards. So I wouldn't know how bad they are. It shouldn't be too bad though.
    I did a quick video yesterday
    https://youtu.be/5p6D9L7VA2k?si=iSwV6phMLdE8Kbd_
  10. May 19, 2025 at 11:10 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    What size wheels? Do you prioritize fuel economy or tire durability on the seldom tows? I went from SL to on E on my 20" wheels and hate the ride. Not to mention the increase in tire weight noticeably reduced my mpg. I'm going back to SL. Never had an issue with SL and towing and actually only ever had a tread puncture on the E's ironically. If it were a dedicated or frequent tower, I'd say E for sure. For seldom towing and better fuel economy, I'd go SL. On 18" wheels the ride quality is affected less due to more sidewall but the fuel economy would still take a hit with heavier E tire.
    Gtboosted likes this.
  11. May 19, 2025 at 11:26 PM
    Tundrav82019
    Leo
    Nice video!
    can you post the link for your mud flaps?
    love the wheels, how far do they poke out?
    they are 18x9 with +18 mm offset?
    Gtboosted[QUOTED] likes this.
  12. May 19, 2025 at 11:31 PM
    Gtboosted
    Los Angeles
  13. May 19, 2025 at 11:53 PM
    Tundrav82019
    Leo
  14. May 20, 2025 at 5:34 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I run Ds or Es because I use my truck on hunting ranch with rough rocky roads and tow heavy boat. If I had a pavement princess I would go with Cs.
  15. May 20, 2025 at 6:50 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    On that note I would like to add that I have had some sidewall issues with C rated tires in rocky gravel and I’ve also been glad to have the extra load capacity when I have inadvertently overloaded a truck or two in the past. It’s good insurance at the cost of a plush ride.
  16. May 20, 2025 at 10:17 AM
    rchaney99
    Thanks! Are you running the stock size tires 275/65R18? I am thinking of moving up to 275/70R18.
  17. May 20, 2025 at 10:55 AM
    Tundrav82019
    Leo
    I stayed with Stock, 275/65r18. Very capable and wanted to keep OEM for towing. Going larger will impact gas mileage and possibly odometer. Seems like a lot of trouble for slightly larger tire. Stick with stock. Trust me, they are better in person and stick out some for being an AT. Amazing tire. I don’t hear them at all while driving. Very quiet.
  18. Jun 5, 2025 at 10:25 AM
    Midlifemoto
    Midlifemoto Throw me a rope
    Western NC
    2017 SR5 DC
    6” lift
    Have the C rated on our JK and they ride and wear very nicely. Absolutely will buy them again.
