Tailgate rust
Discussion in '2.5 Gen Tundras (2014-2021)' started by GBurnett, Feb 27, 2025.
  1. Feb 27, 2025 at 3:52 AM
    GBurnett
    GBurnett [OP] New Member
    I have a 2021 Tundra that I bought new, I noticed this rust at the bottom of tailgate, has anyone have this? I took to dealer to see if it was covered under warranty, they are checking with Toyota, stated that it probably is not covered, they have not got back with me. Does anyone have contact information for factory rep?
  2. Feb 27, 2025 at 4:35 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Factory reps are region specific, and you will not get their number. They can however meet you at the dealership. They usually come around 2-3 times a month to each dealer.
    Rust is covered for 5/60 like your powertrain and if the dealer service manager is a good guy/gal they should just take care of it.
    Weird how yours is just between the 2 weepholes. I just checked mine and no rust on the tailgate at all. I have a 21 that just rolled over 40k miles
  3. Feb 27, 2025 at 5:53 AM
    GBurnett
    Thank you for the information, hopefully they will get back with me, this is the only rust that I have seen, truck has 101,500 miles
  4. Feb 27, 2025 at 5:58 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    At 100k on the clock they unfortunately won't do anything for you
  5. Feb 27, 2025 at 6:30 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I would clean it well and see if it returns, maybe treat with some rust converter spray. If you have used your truck bed to do truck stuff it may be metal shavings or residue that is surface rust that collected there when draining out of the bed. I had some surface rust after drilling out sheet metal and the shavings collected in spots and rusted. Freaked me out but turned out to be on top of the paint / bed liner and just needed a good cleaning. YMMV
  6. Feb 28, 2025 at 7:20 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Surface rust will probably not be covered... Usually the dealer sets up the appt between you and the rep. Same issue on my 2016 but a little worse
    Tried the POR 15 treatment, rust came back within a year. Body shop estimate $500. No guarantee which I'm good with..
  7. Feb 28, 2025 at 7:42 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Direct from the warranty and maintenance guide for a 2021 Tundra:
  8. Jun 5, 2025 at 10:12 AM
    Mntundra4
    Mntundra4 New Member
    I have the same thing happening on my ‘20 tundra. Figure out anything on this as far as the fix? Will be a diy for me when I figure out what to do
