Roof crack
Discussion in '1st Gen Tundras (2000-2006)' started by Dustdog, Jun 4, 2025.
  1. Jun 4, 2025 at 6:39 PM
    Dustdog
    Dustdog [OP] New Member
    01, 05 AC 4wd
    stockers
    Can anyone tell me whats going on here? Is this a layer of fiberglass that split?
  2. Jun 4, 2025 at 6:50 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Looks like Bondo, plastic body filler just spooned into a big dent, not the way it should be used BTW. Dig it out and see what you have. Probably a job for an experienced body and fender man.
  3. Jun 4, 2025 at 8:01 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Agree with chunk. Someone probably smacked it driving under one of those height markers at parking garages, or some other height restriction.
    To do the repair job properly requires removing the headliner, which requires removing most of the trim inside, greatly increasing the labor.
    Seems they elected to take a cheaper route. As chunk said, you'll likely need a pro. Good news is you can reduce the cost by stripping out the headliner before hand.
    G_unit3000, Dustdog[OP] and Tundra2 like this.
  4. Jun 5, 2025 at 2:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Removing the headliner from an AC is not hard, just tedious, take your time and give yourself plenty of time to take it slow.
  5. Jun 5, 2025 at 5:36 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    It amazes me the lengths that people will go to just to do the job wrong. I once removed the headliner and pushed out a roof dent on a RCLB (not mine). The dent popped right out. The biggest pain was getting the headliner out. Not hard, but as Tundra2 said, "tedious".
    G_unit3000 and Dustdog[OP] like this.
  6. Jun 5, 2025 at 5:43 AM
    Huh.
    Obviously already answered correctly above; someone poorly used bondo to cover damage and the bondo has cracked because it wasn’t installed properly.
    Looks like a tree branch might’ve fallen on the roof of the truck, or similar, and was filled with bondo, painted over. The bondo cracked (or water got under it) and water getting between bondo and the sheet metal is causing further damage.
    The only real solve here is to rip out the bondo and see what you’re looking at for roof damage. You’ll need to treat the rust you’ll find (it may only be surface rust), take it down to bare metal, bondo properly, then repaint the roof.
  7. Jun 5, 2025 at 5:59 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Strong chance the stuff was applied too thick because rather than doing proper metal work and using it as a finishing touch to even everything out on properly repaired metal with some ripples they depended on the bondo to do most of the work.
    A possible "get it ready for sale as quickly as possible" special after someone left the damage alone for most of the time they owned it. Slap it on, paint the roof, put a sign on it. Same sort of crap people pull with houses.
  8. Jun 7, 2025 at 9:04 AM
    Dustdog
    01, 05 AC 4wd
    stockers
    The rust underneath is what worries me the most. This is the 1st time in almost 2 years Ive ever seen the roof of the truck to my memory.. im not too worried about removing the interior or even popping the dent myself. Fixing the exterior surface and painting is another story..
  9. Jun 7, 2025 at 9:44 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    dollars to doughnuts there's a "texas spread" of plastic filler on the roof
    ZappBrannigan and Dustdog[OP] like this.
  10. Jun 7, 2025 at 10:56 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Big Surprise…:rofl:
    shifty` likes this.
  11. Jun 7, 2025 at 1:11 PM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    there is even a good possibility a good body man can actually replace the roof sheet metal
  12. Jun 7, 2025 at 1:56 PM
    Retrofit on an OEM sunroof time!!
    PNW15 and whodatschrome like this.
  13. Jun 8, 2025 at 7:45 AM
    whodatschrome
    lots of dents
    My automotive body shop instructor was telling a story about the time he had an employee (at the body shop he owned) that wouldn’t get very much work done during the actual shop’s work hours, but the employee would somehow always manage to have his particular job done my the next morning. And any time he did any bodywork, the part of the vehicle that was repaired would always be covered in primer.
    My shop instructor became suspicious of the guy, so he spent the night hiding up in the second story loft of the shop. Turned out the employee never replaced any of the damaged sheetmetal. What my instructor witnessed, was the employee emptying a full gallon of body filler on the roof of a dented in pickup truck, mixing in the hardener right there on the roof, then spreading it all out smooth with a big squeegee!
    The next morning my instructor confronted his employee about how he fixed the roof. The guy lied and said he sectioned out the sheetmetal. My instructor then proceeded to take a large screwdriver and stab and gouge into the roof of the truck, sinking it in about 1” deep. He then fired the guy right there on the spot.
    My instructor was quite a character. A very nice guy and he was super funny. He coined the term, “texas spread”. He called it that because the body filler was applied so large and so vast, just like the huge state of Texas. So anytime a large amount of filler is applied, i too now refer to it as a texas spread!
  14. Jun 8, 2025 at 8:25 AM
    chunk
    chunk New Member
    I still want to see what's under the Bondo. If it's just a smooth dent, push or pull it out and clean it up, a couple of thin layers of filler, a straight line and R/O sanders, prime, spray bomb Dupli-color and Bob's your uncle. It's not a show truck and it's on the roof.
    Dustdog[OP] likes this.
  15. Jun 8, 2025 at 9:50 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    That happens over time with any bondo that was not done properly.
    Bondo is porous and in a high humid area, the bare metal under the bondo can absorb humidity, or when they were wet sanding they got water into the bondo which wicked down to the bare metal and began the rusting.
    The reason your bondo layer is lifting is due to the rust underneath it pushing it up and the bondo doesnt have anything to hold onto anymore. Time to get a wire wheel out and get busy and see whats under that layer of paint and body filler.
    G_unit3000 likes this.
  16. Jun 8, 2025 at 10:01 AM
    A few years ago @jpink had his roof replaced at the dealership.
    shifty` likes this.
  17. Jun 12, 2025 at 8:12 PM
    Dustdog
    01, 05 AC 4wd
    stockers
    Thats how I feel. Im hoping its a dent. I might try to feel around from inside the cab
  18. Jun 13, 2025 at 4:44 AM
    Dakillacore
    Georgia
    More-so that it's way too thick of a layer. Whoever "repaired" that panel didn't actually properly repair the damage underneath and just slapped a massively thick layer of bondo on. Corrosion protection seems to have been non-existent as well considering the amount of rust that is bleeding through.
    Bondo is supposed to be used as a finishing layer and not used as the actual repair.
    G_unit3000 and shifty`[QUOTED] like this.
  19. Jun 23, 2025 at 1:50 PM
    Dustdog
    01, 05 AC 4wd
    stockers
    Im going to pull the headliner this weekend. Has anyone done it? I found 1 video and one write up. Doesnt seem too bad but Im sure there are some tricks to it
  20. Jun 23, 2025 at 2:22 PM
    I think the big thing, after redoing multiple headliners in multiple vehicles, is: Don't break the interior trim plastics!
    You'll be pulling all the A-pillar and B-pillar plastics, the visors, the dome light, the sunglass/garage door/map light, and potentially seat buckles. The headliner tucks up under all of those things. Once they're all out, the headliner should effectively drop out. We AC guys are lucky, suicide doors make it such that, if you kick the seats all the way back and recline forward OR kick them all the way forward and recline back, there shouldn't be much finagling to get the thing out.
    Now is a GREAT time to have some 80mil-120mil sound deadener (the higher # the better) from Kilmat, Siless, or NOICO on hand with a good roller. You can get rid of a good amount of noise by putting the butyl/tar based heavy mat on the big open expanses of the roof.
    KNABORES likes this.
  21. Jun 23, 2025 at 2:25 PM
    Dakillacore
    Georgia
    It's not bad, just a lot of labor.
    You need to essentially start from the bottom up as everything overlaps. The lower sill plates, the lower and upper center pillar trims, the seatbelts, the windshield pillar trim, the "oh-shit" handles, sunvisors, overhead console, and so forth.
  22. Jun 23, 2025 at 2:52 PM
    Oh and you reminded me - save the dome light and map light in the middle until last. Let those bastards do the heavy lifting of keeping the headliner up.
    Try not to press on the foam/fabric of the headliner, when the foam gets old, rubbing or pressing on it too much can separate the fabric from its foam backing, and you end up with your headliner sagging... Ask me how I know (not on my 1GT, but previous vehicles)
  23. Jun 23, 2025 at 3:48 PM
    chunk
    chunk New Member
    I would dig the Bondo out first before removing the headliner. Depending what you find you might be able to pull most of the dent out. Either way it's going to need a couple of thin layers of body filler which is an acceptable fix. Just what I would do to save removing the interior bits unnecessarily.
  24. Jun 23, 2025 at 5:00 PM
    Dustdog
    01, 05 AC 4wd
    stockers
    I would love to avoid pulling the interior but I dont have any body tools to pull from the outside
  25. Jun 27, 2025 at 6:11 AM
    Dustdog
    01, 05 AC 4wd
    stockers
    Has anyone ordered color matched spray cans?
  26. Jun 27, 2025 at 6:25 AM
    chunk
    chunk New Member
    Duplicolor make good matches for auto finishes in spray bombs, but it might or might not be challenging to get a good result if you plan on painting the whole roof. For a spot repair cover I think it's doable and being on the roof I would try that.
  27. Jun 27, 2025 at 6:53 AM
    @FiatRunner I think?
    FiatRunner likes this.
  28. Jun 27, 2025 at 7:29 AM
    Fragman
    Fragman New Member
    I ordered some from paintscratch.com. They guarantee color match IIRC. I just needed it to fix up where the PO had a battery leak at some point and there was a few mild corrosion spots around the battery tray area. It def matched really well, but I wasn't really trying to blend in or anything, just prevent corrosion. So I didn't do sanding, polishing etc. Just spray, let it dry for a bit and put the tray and battery back in. But color was definitely good (though my paint is in really good shape, esp for metallic green)
  29. Jun 27, 2025 at 8:12 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I’ve used color matched paint from Automotive touch up multiple times, they’ve always been great. Highly recommend. I haven’t been following this thread but if you’re doing some color matched paint, good clear coat is essential. Use SprayMax 2K clear, which is also available from Automotive Touchup.
    https://www.automotivetouchup.com/?...CU7945tRCBBI54irj4tZ12mZDwFavtzkaArC-EALw_wcB
    The Black Mamba, PNW15 and BubbaW like this.
  30. Jun 27, 2025 at 8:27 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Like @FiatRunner ,I have used the Automotive Touchup brand on many occasions and also Dupli-color Plastic Adhesive Promoter that I had. The last project was my ARE tonneau cover latch. I was pleased with coverage and color match.
