USB-C Swap?
Discussion in '3rd Gen Tundras (2022+)' started by RDW, May 14, 2025.
  1. May 14, 2025 at 5:46 AM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    IMG_4328.jpg Anyone know if it would be possible to swap the center console USB dual port charger to the version that comes in the new Tacoma? The Tacoma port appears to be the same size and it supports 45w charging..would be really nice to have this for fast charging and larger devices like iPads.
    RatPanda and ace7m like this.
  2. Jun 4, 2025 at 2:26 PM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    Answered my own question, it is possible! I got it done with the help of @Siblue finding the part number for me.
    Part Number is: 85532-AK010
    Was able to pick it up during the Toyota parts sale... also picked up two prewired harnesses off AliExp to avoid cutting any OEM wiring. Installed today and it works like a charm!
  3. Jun 4, 2025 at 3:31 PM
    Luckydwg
    Luckydwg New Member
    San Diego CA
    2024 MGM Limmited Crewmax Nightshade
    You have a link for the two prewire harness from AliExp l
  4. Jun 4, 2025 at 5:15 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Look in your center arm rest console front driver side - there is a usb type c outlet. Maynot be fast charging but it is there for the using. That is what I use.
  5. Jun 4, 2025 at 6:08 PM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    that’s the one I replaced with this one. I wanted the ability to fast charge the kids’ iPads
    303Gen3[QUOTED] likes this.
  6. Jun 4, 2025 at 6:14 PM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    these two- they’re from the same shop so you should be able to get both for under $10
  7. Jun 4, 2025 at 6:17 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    What are the dimensions on that, I wonder if it would fit the 2nd or 2.5 gen.
  8. Jun 4, 2025 at 6:26 PM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    The wiring is simple. I used heat shrink butt connectors and wrapped everything in fabric tape.
    5 PIN harness:
    -splice together pin 1&5 (positive. Power for charger and backlight)
    -splice together pins 3&4 (negative)
    -De-pin or cut wire from pin 2 (not used)
    2 PIN harness:
    -Black was positive on mine (verify with multimeter and connect to positive wires from 5 pin harness.
    Red was negative, connect to negative wires from 5 pin harness.
    RatPanda likes this.
