How often do you wot?
Discussion in 'General Tundra Discussion' started by EmergencyMaximum, Aug 10, 2023.
  1. Aug 14, 2023 at 10:38 AM
    #61
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I took the restrictor plate off, give the red dragon a little more juice. But uhh, keep that on the down low.
    Corndog123, reywcms, Warreng and 2 others like this.
  2. Aug 14, 2023 at 3:42 PM
    #62
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
  3. Aug 14, 2023 at 4:14 PM
    #63
    2mchfun
    I will say I turn off or disengage the a/c compressor most every single time I nail it to help preserve the compressor regardless of the vehicle. Unless of course my full attention is going to the situation which does happen sometimes. When RPM's are back down, simply turn the dial. Drove several vehicles over 200k and never had a compressor failure. Two clutches. Whoopie! Just too much work and expense that can be easily prevented by not regularly straining it. Motor mounts are another thing not yet discussed.
  4. Aug 14, 2023 at 4:33 PM
    #64
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Guess I’m ready for WOT all day everyday! Plus they’re red so that’s worth additional gains.
  5. Aug 14, 2023 at 4:38 PM
    #65
    18" TRD Off Road Wheels
    It's meant for motorcycles, but it's got food for thought.
    https://youtu.be/zhUI7MWE_Fc
  6. Aug 14, 2023 at 4:51 PM
    #66
    EmergencyMaximum
    That definitely is aimed more at motorcycles with manual transmissions. Automatics however will work with the engine to prevent strain. If the v8 will happily propel car 45mph at 1,200rpm, I don't see any necessity to drive her at 3,000rpm.
  7. Aug 14, 2023 at 4:57 PM
    #67
    "You paid for the whole tachometer. Use the whole tachometer."
  8. Aug 14, 2023 at 5:08 PM
    #68
    EmergencyMaximum
    Let me tell you what my dog is doing. This is sort of relatable to the engine.
    He sleeps all day and saves all that energy, so that one time when he hears "STRANGER!!!" or "DEER!!!" he will unwind, barking like all hell broke loose.
    Corndog123 and Leo's first like this.
  9. Aug 14, 2023 at 8:10 PM
    #69
    Right, because a biological animal works the same way an IC engine does. :monocle:
  10. Aug 14, 2023 at 9:07 PM
    #70
    centex
    centex New Member
    I’ve never owned a vehicle that didn’t get full throttled at least once a week. Most multiple times a day. Engines need to be worked and full throttle works them. Want to really test an engine? Load up max trailer weight and then go do some 0-60 pulls. Really helps burn the carbon out and seat rings. And yes, I’m very serious about that. Passing people on a two lane black top with a loaded trailer is not an uncommon thing. Know what’s cool? Not a single gauge moved. Why? Because vehicles are not fragile dandelions and are meant to be ridden like the prom queen.
    M14 EBR likes this.
  11. Aug 15, 2023 at 4:17 AM
    #71
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I use 0w20.
    I can only go to 1500 RPM.
  12. Aug 15, 2023 at 4:25 AM
    #72
    EmergencyMaximum
    That is dumbest idea ever, gang. You do realize there's more than an engine?
  13. Aug 15, 2023 at 4:53 AM
    #73
    centex
    centex New Member
    Yup. And it’ll all take it like a champ.
  14. May 28, 2025 at 4:21 PM
    #74
    EmergencyMaximum
    Anyone WOTing recently? Any CEL's?
  15. May 28, 2025 at 4:59 PM
    #75
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    I go WOT in the '07 as often as the conditions allow, 90 comes on quick when going 50 and it's fun.
    EmergencyMaximum[OP] likes this.
  16. May 28, 2025 at 5:03 PM
    #76
    EmergencyMaximum
    Supercharged? Do uphill!:burnrubber::bananadance:
  17. May 28, 2025 at 5:49 PM
    #77
    M14 EBR
    Normally aspirated with a free flowing Dirty Deeds cat-back and an old school DAP tune, it's a quick combo in a lighter weight 5.7L RWD RCSB with the towing package.
  18. May 28, 2025 at 5:50 PM
    #78
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    OP why did you resurrect this thread lol.
    Here’s my opinion..
    If my 3rd gen can do this your 2nd gen should not even break a sweat or blow anything up. Just send it give her hell the truck will probably like it.
    Also listen to this.
    https://youtube.com/shorts/qA7G9CINA1c?si=9CThKUB_4kjbx5s-
    j_supra and EmergencyMaximum[OP] like this.
  19. May 28, 2025 at 6:04 PM
    #79
    blenton
    blenton New Member
    You’re not wrong..
    So, the other day I was stuck behind a couple of dawdlers on a country highway that couldn’t decide if they wanted to go 25 or 55 so I decided to put the foot down and pass them. I had manually downshifted a few times but thought I was in 3rd when I was really in second. The Whipple was whinnin and the exhaust was singing when I accidentally bounced it off the rev limiter just as I pulled next to the car I was passing. Startled the driver next to me as much as it startled me. Oops.
    But WOW did that thing sound good zingin around 6k! That’s with 220k miles on it..
  20. May 28, 2025 at 6:23 PM
    #80
    EmergencyMaximum
    That was beautiful, but over redline!!? How is she not exploding? I am not man enough to even think of it!
    Bumped thread for 3rd gen gang to chime in:)
  21. May 28, 2025 at 6:59 PM
    #81
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    All day, every day.
  22. May 28, 2025 at 9:31 PM
    #82
    blenton
    blenton New Member
    Redline is more of a... suggestion... or guideline. So I'm told. My face already feels like when I hit 5k...
    ...although I'm sure it looks more like this...
    ...but I don't want to end up looking like this permanently, so I limit my redline encounters. Out of safety. For my face. And small children that might see it.
  23. May 28, 2025 at 10:02 PM
    #83
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Every. Single. Day. That WOT throttle downshift into second gear from 75km/h is just beautiful. I do that daily on my way home, accelerating onto the same stretch of highway. I let it shift at redline and then just maintain highway cruising speed. I'll do the occasional free rev or burnout off the limiter too. Just to show off my exhaust or for videos lol. Keeps the engine clean and young lol. 380km on the odo and not worried one bit. I keep the fluids clean. Doesn't leak, doesnt burn. No engine light or issues in over three years of my ownership. :thumbsup:
  24. May 30, 2025 at 4:37 PM
    #84
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I’ve WOT a few times. Every time I get on it, not WOT, it puts a smile on my face. :D I love the sound of the TRD exhaust. To me, it sounds like a race truck. :p
  25. Jun 4, 2025 at 2:27 AM
    #85
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I WOT several times a week if I'm driving on the highway or trying to get around someone. She has good roll on power.
    j_supra likes this.
  26. Jun 4, 2025 at 6:50 AM
    #86
    mayan
    Mayan
    DFW
  27. Jun 4, 2025 at 7:09 AM
    #87
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    I'll give the converse! I am a granny driver, like 90+ years old probably shouldn't have a license anymore granny.
    That car you got stuck behind the other day going slow on the two lane road, that was me in my other vehicle...
    2k RPM is my limit..
    I jest of course. While I don't WOT daily, I'm not afraid of hitting 4.5-5k RPM passing, pulling a trailer, or whatever. That is where the power is at on a Japanese DOHC motor. This isn't a domestic push rod motor that can't handle the rotational force...
    I had this talk with my wife also. He has a CX-5 and sees me getting to the upper area of the tach and starts freaking out. Same as above, Japanese DOHC motor, all the power is up top. Plus, GDI requires heat to prevent carbon build up, heat comes with RPM.
    My Miata on the other hand, that little bastard lives at the rev limiter. That whopping 85hp motor needs to scream to get speed. Sure does sound like your going fast when you do it though! :D2
  28. Jun 4, 2025 at 7:20 AM
    #88
    Outbound
    Aaron
    Northern Alberta
    I get on the freeway as if I'm leaving a F1 pitstop.
  29. Jun 4, 2025 at 7:27 AM
    #89
    Silver17
    Northeast
    Gotta go WOT now and then and exercise those VVTI solenoids…if you’re looking for more excuses to WOT. :thumbsup:
  30. Jun 4, 2025 at 7:40 AM
    #90
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I believe 'Redline is a Goal, Not a limit' plays into this.
    My 5.7 RCSB and our $1.75/litre fuel costs - Don't recall ever hitting WOT since initial test drive when
    I bought it over a year ago.
