Power Folding Mirror Button while Vehicle Off
Discussion in '3rd Gen Tundras (2022+)' started by Wraith, Jun 3, 2025 at 6:26 PM.
  1. Jun 3, 2025 at 6:26 PM
    Wraith
    Wraith [OP] New Member
    '25 Limited Crewmax
    I have a 2025 Limited and right away I noticed that once the vehicle is off, you can't do anything with the power folding mirror switch. It won't respond to any setting... In, out, or automatic. I have to turn the truck back on to get it to work.
    Am I just stuck with this as intended bad design now or is this a glitch? My 2012 Limited Tundra could always fold the mirrors in or out with the truck off.
  2. Jun 4, 2025 at 5:48 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I don't know if I've ever tried using the button while the engine was off. Figured it would work the same as windows, whereas it would operate for a short time until you open the door. I do know you can change the behavior of when they auto fold. I have mine fold when I turn the engine off, versus when the truck is locked. I think I used Carista to change that?
    GODZILLA likes this.
  3. Jun 4, 2025 at 6:12 AM
    DRP
    DRP Old Member
    Dave
    Just checked and it is an option in the Carista app. :thumbsup:
    j-utah and Blufin like this.
  4. Jun 4, 2025 at 8:39 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    My 24 always folds mirror closed when shutting down engine.
  5. Jun 4, 2025 at 12:44 PM
    Wraith
    '25 Limited Crewmax
    Yeah I don't like automatic folding because I feel that will wear out the motors faster.
  6. Jun 4, 2025 at 1:07 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Mine fold in when locked with fob, if I manually lock with door switch they don't fold in. I've never tried it with truck off. Works fine as it is for me. You can turn them on or off in settings.
  7. Jun 4, 2025 at 1:28 PM
    g4waldo
    So you're really wanting them to be on manual so you can occasionally fold on demand, though I imagine a few times you've forgotten to do so before the truck was shut off. If I remember I'll set mine to manual until after I shut it off tonight.
  8. Jun 4, 2025 at 2:05 PM
    Wraith
    '25 Limited Crewmax
    Yeah exactly. The 2012 you could push/click the mirror button for in or out any time the truck was completely off.
  9. Jun 4, 2025 at 2:40 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    As others have stated, maybe just have the auto feature turned off?
    It's in your manual..
    But that wouldn't fix your wanting to fold them with the truck off..:(
  10. Jun 4, 2025 at 3:55 PM
    g4waldo
    I used that button on my 2007 so much over 16 years the image was completely gone.
    My 2023 does the same thing. When manually folded out, they will not fold after ignition off. I don’t have Carista to test, but wondering if you could have it manually out, then switch to automatic after engine off, and would a FOB lock fold them in?
  11. Jun 4, 2025 at 4:15 PM
    Wraith
    '25 Limited Crewmax
    I do have Carista, what do you suggest I change settings on there before trying that scenario?
  12. Jun 4, 2025 at 4:16 PM
    GREENPUS
    GREENPUS New Member
    Scott
    You can also push the start button once to power on mirrors and close then hit the start button twice
    1lowlife likes this.
  13. Jun 5, 2025 at 6:03 AM
    g4waldo
    Assuming their site is right, in the Mirrors section of Carista is the below. I believe "With door locks" is the default setting, so if you haven't changed anything it should already be that way. I have mine set to "With ignition". If yours is default, then try having it set to manual out when you turn the ignition off, then change the switch setting to auto. That might let them fold when locking with the FOB.
    • Auto fold side-view mirrors (req. power folding mirrors)
      With ignition
      With door locks
      Disabled
