Dipstick tube to Oil Pan leaking
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joopster, Jun 3, 2025 at 5:48 PM.
  1. Jun 3, 2025 at 5:48 PM
    Joopster
    Joopster [OP] New Member
    I understand I just need to remove a bolt and clip to remove tube and replace o ring.
    What is the easiest way to reinstall? Access through the passenger wheel well or just get it up on ramps?
    Also hope I got the right oring - 10mm ID, 14mm OD and 2mm thick.
    Any tips?
    2010 SR5 5.7
  2. Jun 4, 2025 at 7:32 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    While I have never done the dipstick tube in a 5.7, I have done it on other vehicles and equipment.
    They have all be relatively the same, remove clip/bolt holding it to the block and pop out the tube, install o-ring and put it back.
    Looking at my truck, it seems getting it out can be done through the passenger wheel well. But getting it back in will require being under the truck.
