Infotainment not changing to night mode
Discussion in '3rd Gen Tundras (2022+)' started by Arthughes1, Dec 24, 2024.
  1. Dec 24, 2024 at 6:54 AM
    Arthughes1
    Arthughes1 [OP] New Member
    Northwest Arkansas
    2025 Limited TRD OR
    Recently noticed my infotainment doesn’t change to “night mode” or dark mode when it’s night time with the display setting set to auto. Does anybody know what I could do to remedy this? The screen is bright as hell at night since it doesn’t switch. I
    tried researching but everything points to the auto setting which I have on.
  2. Dec 24, 2024 at 6:56 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    Try reducing your screen brightness by one click.
  3. Dec 24, 2024 at 7:35 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    If your phone is connected through car play or android auto, it can also be a setting with your phone.
    I personally use android auto and Waze for navigation. I have mine set on dark mode 100% of the time, day & night.
  4. Dec 24, 2024 at 7:59 AM
    Hella Krusty
    Hella Krusty New Member
    On the JBL you can set it for day, night or auto. I, same as Raven said, leave it on night mode 24/7
    When I did dable with CarPlay it was on all the time, which I did not like but in fairness I didn’t even look into changing it.
  5. Dec 24, 2024 at 9:22 AM
    Arthughes1
    Northwest Arkansas
    2025 Limited TRD OR
    The weird thing is my phone will switch to night mode, but the rest of the infotainment doesn’t. When I first got the truck, the screen would somewhat dim at night. Now it’s so bright I have to manually turn it down then back up during the day.
  6. Dec 24, 2024 at 9:22 AM
    Arthughes1
    Northwest Arkansas
    2025 Limited TRD OR
    I may just have to go night mode full time. I did the same when I had the 4Runner but liked having it change and get brighter during the day
  7. Dec 30, 2024 at 4:17 AM
    nodak67
    nodak67 New Member
    JR
    if i remember correctly, auto is dependent on headlight sensitivity setting. not sure if it affects dark/light mode but all interior lights dim when the headlights come on i think
  8. Dec 30, 2024 at 6:40 AM
    Arthughes1
    Northwest Arkansas
    2025 Limited TRD OR
    Update… pulled the dash and found one connector was ever so slightly unplugged. Not sure exactly which one it ended up being but I unplugged and re plugged every connector that was removed to install the Beatsonic amp. That included the two connectors that aren’t used for the install, but make it easier to access the others. (Black and brown)
    Tundrastruck91 likes this.
  9. Dec 30, 2024 at 6:02 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Wish Tundras.com had a dark/night mode like tacomaworld.
  10. Jun 2, 2025 at 6:31 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Easy remedy, just get Dark Reader from the chrome store.
  11. Jun 2, 2025 at 11:38 PM
    Tundrastruck91
    Wow, had no clue ...best 9.99 I've spent in a long time. THANKS !!
  12. Jun 3, 2025 at 6:27 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I just use the free version....lol $0.00
  13. Jun 3, 2025 at 4:59 PM
    Tundrastruck91
    No free version listed but not one to deep dive over pennies.
    phabej likes this.
  14. Jun 3, 2025 at 5:18 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Paid version might be good for all platforms if you use a login . Even better
