SPC UCA Groan/Creaking
Discussion in 'Suspension' started by Boisefly, Jun 3, 2025 at 1:26 PM.
  1. Jun 3, 2025 at 1:26 PM
    Boisefly
    Boisefly [OP] New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Man, I haven't posted on this forum in a long, long time. But, I still have my tundra and its been my most reliable, fun vehicle I have ever had.
    Anyways, I installed SPC UCAs about 30,000 miles ago with my Toytec lift. Loved them up until they got insanely loud about 5,000 miles ago. Whenver I go over speed bumps or large dips in the road, I would hear a LOUD, creaking/crunching/groaning noise. It was insanely loud. Couldn't figure out the cause for awhile until I realized it was the UCA bushings. Not the ball joint, but the bushings that ride on the long through bolt. Found on many forums that this is a typical issue with SPC poly bushings. Never heard about this before researching.
    So, I had to remove the UCAs, grease the metal sleeve and entire bushings. Noise is gone now. I greased everything when I first installed but I guess they require maintenance. Anybody else had this issue?
    455h0le_dachshund likes this.
  2. Jun 3, 2025 at 1:30 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I had that issue about a year ago, BUT mine had other issues as well that caused me to have to replace them. That is how I fixed the problem.:( not a cheap fix when you are broke lol
    Boisefly[QUOTED][OP] likes this.
  3. Jun 3, 2025 at 1:37 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. Jun 3, 2025 at 2:30 PM
  5. Jun 3, 2025 at 2:32 PM
    The Black Mamba
    DFW
    Imma keep it stock
  6. Jun 3, 2025 at 5:20 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    ~2yrs ago sounds about right for the time window in which SPC was having some issues with their UCA bushings (and ball joints for that matter). If you were to get modern replacement bushings they will look different. Servicing a poly bushing from time to time is not unheard of nor unexpected though.
  7. Jun 3, 2025 at 5:27 PM
    Boisefly
    Boise, ID
  8. Jun 3, 2025 at 5:28 PM
    Boisefly
    Boise, ID
    Interesting. What modern bushings are you referencing? Press the old ones out and use some of the new ones?
  9. Jun 3, 2025 at 5:35 PM
    memario1214
    Colton
    Missoula, MT
    As long as they're still tight, and your greasing quieted them, you're okay. But they did a revision. You might even be able to contact SPC about getting yours warrantied out!
  10. Jun 3, 2025 at 6:10 PM
    I wonder what they changed from years ago. Mine are 5 years old and no noise or issues at all. I do need to contact them and ask why they say to torque the ball joints to 45 ft lbs when Toyota spec is 81 ft lbs.
  11. Jun 3, 2025 at 6:17 PM
    memario1214
    Colton
    Missoula, MT
    They were good for years, then I think they changed suppliers, and everything went to shit. I've always wondered that about the castle nut thing, but as long as the cotter pin goes through and they're snug it's no issue.
  12. Jun 3, 2025 at 6:31 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    It’s a bit of a pain but I do the Total Chaos greasing every oil change and hit with dry spray more often than that, they are pretty quiet so far (3 years). That’s wild SPCs have no zerks.
    Leaf springs get noisy too if offroading as I think sand gets in between the leafs, I just hit those with wd40 and seems to go away.
  13. Jun 3, 2025 at 6:34 PM
    When I replaced them I torqued them at 45 ft lbs per SPC and had vibrations ever since. @Yota303 pointed out that OEM spec is 81 ft lbs. When I pulled the Toytecs out to install the 8112's I torqued them to 81. After the new ball joints, retorque, and installing the Bilsteins, the only vibration that I have is from tire wear on the passenger side where the alignment was off, but Ridge Grapplers aren't going to be totally smooth anyway.
  14. Jun 3, 2025 at 6:37 PM
    memario1214
    Colton
    Missoula, MT
    I can honestly say that I have never torqued them to 45, but rather don't find that value to be "problematic". I probably land around 60.
    HulkSmurf14 likes this.
  15. Jun 4, 2025 at 7:48 AM
    455h0le_dachshund
    455h0le_dachshund Human tongue feels aluminum plate
    Rev. Hotdog
    TX...big surprise
    The SPC uppers ball joints?
    It's 45 ft lbs while adjusting and 150 ft lbs when done.
    The Black Mamba likes this.
  16. Jun 4, 2025 at 7:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Re-read #12 and #16
    That explains the alignment issues and vibes.
  17. Jun 4, 2025 at 8:32 AM
    #12 is the nut on the ball joint stud where the cotter pin is. SPC states 45 ft lbs and that's it. Toyota spec is 81. #16 is the top nut that holds the ball joint to the control arm.
  18. Jun 4, 2025 at 8:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah I thought you were talking about the top nut
  19. Jun 4, 2025 at 10:35 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You could drill a hole, thread it, and insert your own zerks...easiest, cheapest and potentially, the best solution. They also offer new bushings for the UCAs that I had to recently redo on my 4runner...they are better and definitely do not make noise...they're also not Poly but more of a hard rubber...maybe the same thing but they aren't your typical poly bushing...I like them and haven't had any issues for about 3 months of driving...it was the last thing I wanted to do and if I have to do this again, SPC is done on my vehicles...though, I'm hopeful the updated bushings are the fix I was hoping for...perhaps a different use-case than what you're experiencing...
