Sub box help
Discussion in 'Audio & Video' started by Toddow, May 17, 2025.
  1. May 17, 2025 at 1:53 PM
    Toddow
    Toddow [OP] New Member
    2018 metallic gray TSS
    After market radio
    Looking for specs to build a sub box to fit behind my rear seat of a 2018 Tundra CrewMax.
    It’s a 10” sub with mounting depth 4-7/16”. Needs .625 cubic feet air space for sealed and 1.0 for ported. any help would be greatly appreciated. Thank you
  2. May 21, 2025 at 4:03 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    Reach out to james at tech 12 volts. He will build a very nice box get it to you. It will fit perfect AND he puts resin in it to make sure it’s sealed up tight. For the price of materials and time you will spend getting a box from james is a much better investment. Also, he will find out what speaker you are using and make sure it fits and the cut out is perfect.
  3. May 22, 2025 at 9:48 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    So many easy options if you move the seat forward with Gately brackets. I have a single 12 in 1.7ft ported enclosure. Not even close to full width. Getting a foot back there is easy!
  4. Jun 3, 2025 at 10:40 AM
    Snert
    Snert New Member
    2021 SR5
    Can say from experience it's an extremely tight fit back there. With the hanging mat that covers the the rear window access panel removed, you've got about 7.5" bottom depth and top depth depends how tall you go. Have to also take into consideration how far your sub surround sticks out from the front and how much excursion it has. Sub has to basically nestle/play into the seat back of either of the side seats. Best thing to do would be message James at Tech12Volts like @Iamsecond mentioned, otherwise if you're dead set on building yourself I'd recommend getting some cardboard or foam poster board from dollar tree to create a mock up, and use a free sub box volume calculator to figure your top/bottom depth, width and height.
