Need Help! Idiot Reversed Battery Hook Up…
Discussion in 'Electrical' started by Harks7504, Jun 1, 2025.
  1. Jun 1, 2025 at 5:39 PM
    Harks7504
    Harks7504 [OP] New Member
    White TRD Tunny
    IMG_3642.jpg IMG_3641.jpg IMG_3639.jpg IMG_3642.jpg IMG_3641.jpg IMG_3642.jpg IMG_3641.jpg IMG_3642.jpg IMG_3642.jpg IMG_3641.jpg IMG_3642.jpg IMG_3641.jpg IMG_3639.jpg Ok, long story short… 2020 Tundra
    Battery dieted from being left on in Accessory power. Co-worker tries to give me a jump (no dice) proceeds to bring a spare battery from shop and not thinking hooks it up even though terminals are reversed… Boom! Replaced Battery. Could start car (with emergency key position, but couldn’t move car out of park without using the emergency release). Car would move but no acceleration. Pretty much lost everything.. radio, windows, cab lights, alarm, key fob, power seats, AC.
    Replaced the fuesable block assembly. Got Shifter back, cab lights, power seats windows, and AC.
    Dash still lighting up like Christmas Tree
  2. Jun 1, 2025 at 6:48 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Damn... this may be deeper than your basic relay... so many computers and modules you may need to get everything tested. Hindsight is 20/20 but next time double check work, even if its a Triple A tow truck driver. As the same thing almost happened to me long ago.
  3. Jun 1, 2025 at 6:51 PM
    I thought if the terminals got reversed it would blow one of the main fuses or something?
  4. Jun 1, 2025 at 7:01 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Definitely need to check the main fuses. Hopefully they did there job and popped before major electrical damage occurred.
  5. Jun 1, 2025 at 7:22 PM
    centex
    centex New Member
    I made that mistake myself on my blazer recently and let the smoke out of the wire from the alternator and main junction block. Popped several fuses. Shit happens.
    Check the fuses and also have someone clear the codes. These trucks do weird stuff I’ve learned when certain codes get thrown. Example is mine threw some o2 codes and it made the truck run really rough and vibrated really bad. Cleared the codes and back to smooth as a sewing machine.
  6. Jun 1, 2025 at 7:34 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That’s correct. Usually it will blow the main fuse. If that doesn’t happen you can get all kinds of fun stuff, as evidenced by the cornucopia of errors demonstrated here.
    I would manually check all the fuses. Then I would reset the modules and see what errors come back and go hunting from there.
    Black Wolf likes this.
