  1. May 28, 2025 at 6:11 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Both are mild abrasives, but I haven't tried the magic eraser yet.
  2. May 29, 2025 at 11:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My quick go-to level for doing wife stuff is an old plastic 12" that resides in a bottom cabinet drawer.
    The bigger ones hang on the wall.
    I decided to look for something magnetic I could slap to the side of the tool chest and purchased this.
    PREXISO 2-in-1 Laser Level 12 in Spirit Level with Light, 100Ft Alignment Point & 30Ft Leveling Line, Magnetic Laser Leveler Tool for Construction Picture Hanging Wall Writing Painting Home Renovation - Amazon.com
    It has 2 lasers, a dot and a line, it also will illuminate the spirit levels if needed.
    One side is magnetic with a groove on the magnetic end for attaching to metal pipes.
    Not bad for $40...........
  3. May 29, 2025 at 12:25 PM
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    Refinished a 25 year old kitchen table that was in need.
    Sanded off the old finish, down to the naked wood.
    Instead of stain, I used a roofing torch to darken the wood and bring out the grain.
    ... and several coats of poly.
  4. May 29, 2025 at 12:56 PM
    NWPirate
    Zach
    WA
    That looks awesome, nice work.
    What brand and finish of poly sealer did you use?
    woods and Noobo Baggins[QUOTED] like this.
  5. May 29, 2025 at 1:26 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Spreading yards of mulch........someone make it stop.
  6. May 29, 2025 at 2:17 PM
    Noobo Baggins
    Glenn
    Minwax Polycrylic - satin finish
  7. May 29, 2025 at 2:53 PM
    RobertD
    Robert
    DFW, Texas
    That's pretty sweet. Thanks for sharing
    1lowlife[QUOTED] likes this.
  8. May 29, 2025 at 3:05 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    what a transformation! I wasn't expecting such a dramatic result. Looks great, thanks for sharing!
  9. May 29, 2025 at 4:07 PM
    NWPirate
    Zach
    WA
    :fistbump:
  10. May 29, 2025 at 6:05 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    Looks great! Now I wish I'd had a torch when I did a similar job about 6 or 7 years ago. I just went with stain. Then we had a kid who beat it up by banging his spoons against it when he was learning to eat solid food...so I've accepted I won't have a nice dining table for a few more years, not until both my boys are older.
  11. May 31, 2025 at 4:09 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    We have a few rugs that were a "good idea" but now I absolutely hate. Everytime I watch my girls coloring with marker directly on top of them tho makes me think "well, maybe we should wait a couple of years"
    The rugs I hate are those washable rugs that have been being pushed. They sound like a good idea, but two problems. 1) they realistically ain't fitting in your washer machine, at least not for anything larger than a runner and 2) They are so lightweight, they move constantly and my vaccuum (battery powered stick, not even a "real" one) sucks them up even on low. I have to power it down alllll the way so it barely picks up dirt.
    Do not buy these things folks! Go to a tag sale and find some nice old rugs from someone whose dead and enjoy them.
  12. May 31, 2025 at 10:20 AM
    Noobo Baggins
    Glenn
    I bought the roofing torch on Amazon for $50 or so several years ago.
    Not for roofing ... but for another woodworking project. I've actually used it quite a bit.
    Also works great in the winter for melting those icy patches in the driveway and walkway.
    I've also used it for weed control in the yard. Dandelions and such.
    woods and rmeyer7[QUOTED] like this.
  13. Jun 1, 2025 at 8:30 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Made some window "solar screens" from Suntek 90 material.
    Lessons learned: while the screen does stop most UV, the material will still radiate heat to the window pane if too close; space between the material and window reduces that problem (well newer more efficient windows would also solve that but not in the budget at the moment). So now I am bumping out the screens with 1" aluminum spacers to allow for air flow between the screen and the window.
    Around the times the house was built the average temps in my area hovered in the low to mid 70's in the day and 40-50's at night. Fast forward 35 years or so and the temps get into the 90's-100's in the day, and lucky if they drop under 70 at night.
    Fotnot likes this.
  14. Jun 1, 2025 at 8:35 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    Those torches are great, purchase a Red Dragon branded torch a few years ago. Used it to char wood for outdoor planter boxes. Not only did it look great, the wood held up really well in the hi desert sun.
    Noobo Baggins[QUOTED] likes this.
  15. Jun 1, 2025 at 8:38 AM
    Today I learned. Hardie Siding can "rot". Previous owners had this installed and there was no step flashing done. Hardie Siding needs to be able to dry out after rain. Because the gutter was directly against it with no gap and inadequate flashing it is disentegrating. Water has also gotten behind the siding and rotted part of the soffit framing. Because Hardie siding is blind nailed, it's hard to replace just one piece. I've been watching YouTube videos. Not a lot of good content on it.
    Anyone have experience with Hardie Siding repair?
    Fotnot, ATV25 and woods like this.
  16. Jun 1, 2025 at 11:23 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Had to replace some fascia that was Hardie board. I just used a small masonry bit drilled holes a little bigger bit to countersink and then just wood screws to attach it a little caulking and paint good to go
  17. Jun 1, 2025 at 6:51 PM
    Florida AF
    Logan
    North Florida
    Very happy this weekend is wrapping up and I can take a break by going back to work... I am tired...
    upload_2025-6-1_21-50-19.png'
    Lots of tree work to prepare for the upcoming storm season... Got a lot trimmed back and now I have several days of dragging and clean up to do. Fun times..
  18. Jun 1, 2025 at 6:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Fiber cement - it’s great…until it ain’t.
    like ATV25 said, you can face nail it in less conspicuous places by drilling pilot holes and caulking over the faces with a good exterior paint-grade caulk.
    where the end of that gutter is, i’d run a full piece of flashing behind the roof L-flash and up under the upper piece of siding that extends below the gutter and out in front of it a bit as well.
  19. Jun 2, 2025 at 6:42 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Started framing for the Walipini greenhouse (underground greenhouse). We got the hole going, the first 10x10 section is about ready with just some clean-up and trimming the walls back. Its been open for 5 years without any sign of cave in. The ground where I am in Montana is a mixture of clay, limestone and a bunch of rock (quartz, granite, etc). The depth is 7' in ground, the roof will be a lean to style angles towards the sun for maximum light and passive heat. We are pulling out all the stops on this with things like 55 gallon plastic drums filled with water and painted black for heat retention. The idea is not to have to heat it through the winter months. 6 mil plastic will go on this year as a first run to make any adjustments before the poly plastic roof is put in place. Ultimately it will end up being 10x30. The next phase will be cold storage/root cellar/processing area at 10x20 running across the front of the greenhouse with about a 5' spread. A tunnel will join the two areas so we can come out of the house, go down a small set of stairs into the cold storage room, then through the back of that in a small tunnel into the greenhouse. This will save the nasty walk at -50 temps in the winter time to get fresh fruit and veggies!
    Tripleconpanna, Fotnot, woods and 6 others like this.
  20. Jun 2, 2025 at 2:49 PM
    justcuz
    justcuz 2.5 Gen Member
    Completed river rock unload from truck into flower beds. Just have to get some plants now. IMG_0392.jpg IMG_0391.jpg
  21. Jun 2, 2025 at 6:00 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    How does it feel up there? Smooth movements or pretty shakey?
    Post some photos!
  22. Jun 4, 2025 at 4:12 PM
    Not me, but I paid a company to stabilize my foundation with carbon fiber straps. The wall was bowing and tilting. In a few days I'll paint over them so it won't look as goofy.
    I'll eventually have to do the rest of this wall but that will cost a lot more. The rest of the basement is finished so I'll have to rip out a shower and all the sheetrock. I'm considering a drain and sump pump too. Carbon fiber straps would stabilize the wall but won't prevent water intrusion down the road.
    woods, Chris the Ogre, BroHon and 5 others like this.
  23. Jun 5, 2025 at 1:36 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Were you the one who posted some of this a while back? Neat to see some real photos of it, looks like they did a very clean job!
    Too bad you have to invite them back!
  24. Jun 5, 2025 at 2:46 PM
    Yes I mentioned it before and finally got it done after getting three quotes.
    OldGuy03 and woods[QUOTED] like this.
