Pay it forward----> free goodies.
Discussion in 'Marketplace' started by dcsleeper408, Apr 14, 2016.
  1. Jun 1, 2025 at 4:25 PM
    #2251
    biebs96
    PA
    I’ll take it if, the other guy passes.
  2. Jun 1, 2025 at 4:34 PM
    #2252
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Pile of Baja Designs harnesses
    Box contains:
    • Three harnesses - break-out to two separate lights, two wires (+12V and Ground) per light, with backlit toggle switch and relay. BD SKU 640117
    • QTY 8 end connectors/terminal kits from factory lights (female terminals, two-wire connector, and insulation plugs). these are the same as what is already on the wiring harnesses, but could be useful if modifying/shortening those harnesses.
    • QTY 8 male connector housings (housing only - this is the connector that comes pre-installed on the BD lights).
    Box is 4.5 lbs (12x10x5). I'm asking you to cover shipping, but otherwise just want it gone.
    bulldog93, Mater, TRDFerguson and 6 others like this.
  3. Jun 1, 2025 at 9:26 PM
    #2253
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Would be a whole lot cooler if there were toes visible in this pic :boink:
    jewsNbrews, oddhours, biebs96 and 4 others like this.
  4. Jun 1, 2025 at 9:40 PM
    #2254
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Sent it over to you so you could mock it up with your Voodoo rack..
    and I received it from @1lowlife . He sent it over with a magical quarter in a little ziplock baggy. I kept the quarter :p; sits in its baggy on my toolbox
  5. Jun 1, 2025 at 9:50 PM
    #2255
    RainMan_PNW
    Casey
    Clark County, WA
    Damn - you’re right!
    Now it’s on the way to a new home. This thread just keeps giving…
  6. Jun 1, 2025 at 9:51 PM
    #2256
    RainMan_PNW
    Casey
    Clark County, WA
    You realize that up here in the PNW we have to keep our toes inside of goretex shoes…or at least birkenstocks with wool socks.
  7. Jun 1, 2025 at 9:58 PM
    #2257
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    NOT THE SOCKS IN THE ‘STOCKS
