35x11.5x20 failed the rub test
Discussion in 'Wheels & Tires' started by garciahomes, May 28, 2025.
  1. May 28, 2025 at 5:21 PM
    garciahomes
    garciahomes [OP] New Member
    I had Discount Tire mount a Nitto 35x11.5x20 tire on my Wicked 20x9, 0 offset wheel and it was rubbing on the body mount, and real close to the outer 'ear' looking like thing near the front of the tire.
    I have a 3" Extreme Terrain lift/leveling kit on it, mud flaps removed, plastic near fogs removed. Currently on 33x12.5x20 Geolander mud terrains. No rubbing.
    Any ideas?
  2. May 28, 2025 at 5:36 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Get closer to OEM offset, ideally about 45mm.
    Lord Helmet and blenton like this.
  3. May 28, 2025 at 5:39 PM
    garciahomes
    Thanks for the quick suggestion, I thought zero offset was in the ball park. Guess its 33's and I move on.
  4. May 28, 2025 at 5:45 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    FWIW, I run 35 x 12.5 x 20 on +18 offset wheels and have no rubbing. This is with TRD Pro Fox shocks (takeoffs) on my 2018 Platinum. I run SPC uppers with ~+6.5° of caster. So im sure you can make those 35s work, but may need some allignment adjustments (and possible aftermarket UCAs to facilitate that). But as @Ponderosa_Pine said above, offset is going to be the biggest factor
    Ponderosa_Pine likes this.
  5. Jun 1, 2025 at 9:35 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I’m betting even a 33/12.50 will rub on a 0mm offset wheel if the alignment isn’t brought into the equation.
    To fit bigger tires, you need to address all of these:
    Wheel offset. Harder to fit big tires with low offset.
    Alignment. Gain room by adjusting caster.
    Minor trimming and massaging. Lose the mudflaps. Heat and push the fender liner. Consider a BMC.
    Big tires fit. You gotta want it though.
    blenton likes this.
