Never replaced suspension, easy as it looks?
Discussion in '3rd Gen Tundras (2022+)' started by Ero2, May 31, 2025.
  1. May 31, 2025 at 8:58 AM
    Ero2
    Ero2 [OP] New Member
    Hey all! So, I've done engine work on several vehicles in the past. Downpipe, cat back exhaust, intake, basic stuff. I've never done suspension, but in watching this video, as long as I buy a coil over and don't need a spring compressor, I'd be silly to pay someone to do this...is it truly that easy? The back is even easier I assume?
    https://m.youtube.com/watch?v=_OI0AWoFjoQ
  2. May 31, 2025 at 9:02 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you can work on cars you can do it
    vtown76 likes this.
  3. May 31, 2025 at 9:06 AM
    pursuit2550
    pursuit2550 New Member
    Very easy. I have the 2nd gen down to a science. Can replace 1 coilover in about 30-45 mins. Search for tips and tricks from the previous gen as the suspension is practically the same setup. 1 tip, disconnect the front sway bar at the chassis and not on the control arm. Disconnect both sides at the same time, makes it easier to work with the control arm.
    vtown76 likes this.
