  1. May 29, 2025 at 8:48 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Welcome from Tn
    Corndog123 likes this.
  2. May 29, 2025 at 9:03 PM
    Fergie
    Fergie New Member
    Ever wonder how much work the skid plates put in? After about 5 years of decent 4 wheeling into my different fishing spots, I can appreciate the protection, even if the moto jack is needed for removal.
    Also, cut a notch in a flathead for removal of parking brake shoe springs, and use one of these tools that only gets used every generation or so to reinstall them! Holy hell was it easy!!!
    Expand the star adjuster until you cannot turn the rotor, back it off 8 notches or so, and you are GTG, then adjust the pedal throw to 6-9 clicks...yeah...that many...and you are ready to roll.
    After R&Ring the diffs, only need to fill the front, double check some torques and I'll be on the road w 5.29s!
  3. May 29, 2025 at 9:38 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I ordered one off of Ebay a while back from KBH Motors...
    I was anticipating a 'cover' (something that goes over the existing material to protect it), and not an actual replacement cover (which is what the product was)...
    This was completely my fault for not taking the time thoroughly read through the description, etc.. qualitiy seems pretty decent from that vendor if they are still around, but you'd have to remove the console lid and disassemble the underside of the console (screws and maybe a clip or two) to remove the old one and reinstall the new one.
    Upholstery shop would be a good way to go if he doesn't want to do the work himself (probably better quality too).
    I'm not sure what color he's looking for, but the one I ordered and never used is black, if he would have interest in that one...
  4. May 29, 2025 at 9:40 PM
    Tripleconpanna
    Also, I'm guessing most of the large vendors like Katskin, etc. would probably sell you just a console cover as well :notsure:
  5. May 30, 2025 at 6:45 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    @timlovestacos that is one clean 2015! Looks bitch'n and done well "debadged".
  6. May 30, 2025 at 7:10 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Oh I'm aware, I've got +1's on my truck now, and a set of +3's in the garage. Just gotta figure out whether the +3 will work with the RAS or if I've gotta do a +2.
    I have yet to look under the truck from my last wheeling trip, but the RCI sliders and skids definitely did their job.
  7. May 30, 2025 at 7:45 AM
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    Had a Duralast battery crap the bed after 7 months. Swapped it out yesterday, but it seems weird that it would drop off so fast. Watching to see if something else us up. Alternator was replaced a few years ago, so I'm guessing that should be ok. Maybe I don't drive it enough? Lot's of short 10 minute drives for the most part, so maybe I'm not giving the alternator enough time to charge the battery back up. I hate electrical stuff about as much as I hate transmission stuff. Ugh.
    I will say that Andy over at Autozone is not only a legit truck guy, but a heck of a customer service / sales associate. It great to see there are still a few at the autoparts stores that walk the walk.
    Corndog123, atc250r and bulldog93 like this.
  8. May 30, 2025 at 7:56 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Sometimes you just get a bad one.
    Corndog123, MVRCA, BR73 and 1 other person like this.
  9. May 30, 2025 at 8:17 AM
    centex
    centex New Member
    Batteries have been crap since covid. I've replaced every one I've bought inside of 3 years or less. Various makes and models. I'm waiting to see when the costco one in Tundra dies.
    Corndog123, woods and MVRCA like this.
  10. May 30, 2025 at 8:48 AM
    amc_
    amc_ New Member
    Washington
    2018 Tundra Platinum CrewMax 4x4
    Shoutout to @memario1214 - I ordered the Eibach Pro 2r kit Monday and it arrived yesterday. Just waiting on the durobumps, which should be here Monday. Started soaking all the bolts with PB Blaster already, and hopefully I can find a day in the next week or two to tackle the install. I'll post up some photos when I get it done.
  11. May 30, 2025 at 8:52 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    :fistbump::fistbump: Appreciate the support! Glad we were able to get things wiggling quickly
  12. May 30, 2025 at 10:31 AM
    AREDRIG
    AREDRIG New Member
    Luis
    18 tundra double 6.5 barcelona
    Kicker tweeters that were suppose to go in center ended up on corners and sound great with the Sony radio
  13. May 30, 2025 at 11:10 AM
    centex
    centex New Member
    Just picked it from the valvebody install. I got the extreme version and I wouldn’t call it extreme at all. The 1-2 and 2-3 are quick and solid but not firm or harsh. The rest of the gears and lock up aren’t really any different than stock other than they are now felt instead of just gears.
  14. May 30, 2025 at 1:09 PM
    Wishbone Runner
    Wishbone Runner Toyota Connoisseur
    2019 Platinum
    Please don't use chain for ANY recovery, good way to kill someone.
  15. May 30, 2025 at 1:34 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I think most complaints come from stop/go traffic. Have you been able to replicate that type of low/no throttle shifting?
  16. May 30, 2025 at 1:47 PM
    centex
    centex New Member
    Unfortunately I live next to a city so plenty of that. Zero issues so far.
    Corndog123 and bflooks like this.
  17. May 30, 2025 at 3:30 PM
    justcuz
    justcuz 2.5 Gen Member
    Did the Tundra squat while hauling a yard of river rock. IMG_0384.jpg IMG_0386.jpg
  18. May 30, 2025 at 7:23 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Picked up some UCA bolts from Camburg. I’ve heard stories about the stock ones being seized in place, so I figured $40 was good to know that I’ll have a spare set at install time. And I think replacing hardware isn’t really ever a bad idea anyways.
  19. May 31, 2025 at 6:25 AM
    Tripleconpanna
    If I'm looking to check front to back and side to side level of my truck, where are a couple of good points to attach a level to verify??
    Yes, I know the truck is not truly level, but my driveway and the parking stalls on my property are heavily sloped due to the amount of rain we get here so I'd like to get it close at least...
    BR73 and 1794TX like this.
  20. May 31, 2025 at 6:33 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
  21. May 31, 2025 at 6:34 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Center of the hub or ground to the bottom edge of the fender is usually the way. If the slope is more than maybe 15 degrees it'll affect level across the axis affected by the slope, but probably not much.20250531_083127.jpg
  22. May 31, 2025 at 7:12 AM
    Tripleconpanna
    I wasn't think about it from a 'leveled' suspension perspective, but more about having the frame of the truck level for the purpose of fluid checks, etc... Plus to get the vehicle leveled as it would be in a 'shop' on a level pad, I will have to elevate parts of it which will force the suspension to flex and articulate and those measurements will be way off.
  23. May 31, 2025 at 7:22 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Ah - -
    It'll take crawling under it - but since you're going to be doing that for the fluid change anyway, put the level on the frame. Not sure any other way could ever be perfectly accurate.
  24. May 31, 2025 at 8:43 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Mine came out super easy on my 2015 and around 88k miles in the rust belt. Easy once the nut was loosened!
    bulldog93 likes this.
  25. May 31, 2025 at 9:03 AM
    Rick52Chevy
    Rick52Chevy New Member
    Rick
    2020 Quicksand SR5
    Leveling kit. 33X12.5X20 Klever RT with 20X10 Fuel wheels Ceramic Tinted windows
    Can I ask where you got them? I haven't had luck yet finding them using links I have found in this forum. I need the grab handle for my wife. I have her do things like backing up to the ATV trailer and so forth
    Boneskull420 likes this.
  26. May 31, 2025 at 9:09 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Moved wires from my Haltech flying lead harness over to the Boomslang plug-and-play harness, added sensor inputs, sensor grounds, DPO outputs and CAN plug wiring. I still need to join the sensor grounds, join the 12v switched wires and extend those for termination in the truck. Once I get over my analysis paralysis and choose a mounting location I can get everything trimmed down, terminated and loomed.
    Mdl, Velocity72, bulldog93 and 6 others like this.
  27. May 31, 2025 at 9:11 AM
    Rick52Chevy
    Rick
    2020 Quicksand SR5
    I have used Optima. More expensive, but they really are worth the money. Especially if you are like me and only drive your truck for short trips or don't drive it for over a month sometimes. Then you decide it is time to go wheeling, the battery is the last thing to worry about.
    bulldog93 and MVRCA[QUOTED] like this.
  28. May 31, 2025 at 9:41 AM
    RobertD
    Robert
    DFW, Texas
    https://www.ebay.com/itm/293336326056
    He gets handles often but they go quickly. If you message him, he will sometimes message back when he posts one.
  29. May 31, 2025 at 9:49 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Just keep looking on eBay. I found mine after I lost one that sold to another person.
    Rick52Chevy[QUOTED] likes this.
  30. May 31, 2025 at 10:01 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
