Howdy! Come watch me polish a turd.
Discussion in '1st Gen Tundras (2000-2006)' started by Nimitz_, May 30, 2025.
  1. May 30, 2025 at 12:46 PM
    Nimitz_
    Nimitz_ [OP] LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Hey guys, I just picked up a 2006 DC with 4wd and a V8. She’s in pretty rough shape so it’s it’s a little tough to post up next to all these beautiful trucks, but I want to say hi and thank you all for all the info I’ve gotten already.
    She’s pretty rusty and the drivers seat looks (and smells) like a badger lived in it but it’s only got 170k on the clock, 4wd and almost all the body panels are the same color and hey, it was $3500. Anyway, thanks again and sorry in advance for 10,000 questions. Yes, I’ll search first and I’ve read the pre-buy sticky like 35 times.
  2. May 30, 2025 at 12:48 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    That's a solid pick up IMO. Just a little elbow grease and TLC... She'll be good as new!
  3. May 30, 2025 at 12:50 PM
    How’s the frame? Any concerns about rust through there?
  4. May 30, 2025 at 12:50 PM
    Nimitz_
    Sam
    Seattle-ish
    Thanks! I have a feeling I’m going to need to get my elbow grease at Costco but I’m pretty stoked. Already knocked out steering bushings, bled the brakes poorly and just about to get going on valve cover gaskets. Ball joints are sitting on the front porch as we speak too. It’s just a beater for yard work, but might as well minimize the risk of dying as much as possible eh?
    G_unit3000, OldGuy03, bmf4069 and 3 others like this.
  5. May 30, 2025 at 12:52 PM
    Nimitz_
    Sam
    Seattle-ish
    It’s a little flaky, but fortunately it has a MASSIVE oil leak from the crank shaft seal and I live in a place that doesn’t salt the roads so it shouldn’t get much worse before I can treat it.
    G_unit3000, OldGuy03, BroHon and 2 others like this.
  6. May 30, 2025 at 12:57 PM
    Should be okay for yard work. Feel free to to start a thread when you plan to get around to the leak in the crank shaft seal. Plenty of good people here that can answer questions if you like to DIY.
    Nimitz_[QUOTED][OP] likes this.
  7. May 30, 2025 at 1:22 PM
    Nimitz_
    Sam
    Seattle-ish
    Spending 60% of the purchase price to get it fixed is kinda out of the question lol. I’ve been working on Toyotas for about a decade and like to play a fun game my wife hates where I build a project only using used or on sale parts to see how cheaply I can do it. Obviously that excludes things like ball joints and brakes.
    Anyway here are a few past and current builds just so I get a little street cred.
    Bmktw2, Dustdog, G_unit3000 and 9 others like this.
  8. May 30, 2025 at 1:25 PM
    Nice!
  9. May 30, 2025 at 1:49 PM
    Nimitz_
    Sam
    Seattle-ish
    So just off the bat, should I pull this bent ass radiator to make it easier to do the seal and straighten the front end? It works, but I’m assuming the amphetamine enthusiast I bought this from used the cheapest possible part after he hit whatever he hit.
    And for the record I knew this was a heap of shit when I bought it.
    Also let me know if I need to make separate threads for all this stuff.
    G_unit3000 likes this.
  10. May 30, 2025 at 1:56 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  11. May 30, 2025 at 1:58 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Nah, retitle this thread and keep it as your build/ progress thread. That way everything is in one place.
  12. May 30, 2025 at 1:59 PM
    Nimitz_
    Sam
    Seattle-ish
    Better?
  13. May 30, 2025 at 2:09 PM
    Haha. Is the condenser bent as well? Hopefully you still got AC.
  14. May 30, 2025 at 2:25 PM
    Nimitz_
    Sam
    Seattle-ish
    Nah no AC, but I haven’t gotten that far yet. Guessing it’s trashed. The trans cooler is painted black which I’m sure helps with thermal transfer.
  15. May 30, 2025 at 2:27 PM
    Reverse methhead psychology, if you insulate the fins from heat, it’ll hold in the cold better, right?
  16. May 30, 2025 at 2:45 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Oh. This "build" is already interesting. :mudding:
    And I see Renton. Born and raised in Bellevue.
    Nimitz_[OP] likes this.
  17. May 30, 2025 at 2:54 PM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Trans cooler is painted black from the factory
  18. May 30, 2025 at 2:59 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I really like how you're approaching this. You know what you have, and you're not trying to make it something it's not. Following.
  19. May 30, 2025 at 3:20 PM
    Nimitz_
    Sam
    Seattle-ish
    Only half painted gloss black?
    pirates712[QUOTED] likes this.
  20. May 30, 2025 at 3:21 PM
    Nimitz_
    Sam
    Seattle-ish
    I may be fiscally irresponsible but I’m not foolish.
  21. May 30, 2025 at 3:24 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    If the frame, engine and transmission are good, LBJ, timing belt and radiator get done and fluids refreshed (if not done already), then you are left in a great position to do what you can when you can and bring this thing back. I'd probably get rid of the badger first though! :)
  22. May 30, 2025 at 3:45 PM
    Nimitz_
    Sam
    Seattle-ish
    Engine sounds good and trans and trans case both work well. Frame is not great but someone in Michigan would be pretty excited to have it. No holes, just needs to get some love.
    BroHon likes this.
  23. May 30, 2025 at 6:39 PM
    Nimitz_
    Sam
    Seattle-ish
    Alright new headlights and tail lights. No more taped on turn signals for this guy! Fitment was… challenging.
    Redoak and G_unit3000 like this.
  24. May 30, 2025 at 7:13 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for sharing your adventure. I'm interested to see how far you go with it.
  25. May 30, 2025 at 7:19 PM
    Yeah if this were me, I’d be hitting FB marketplace and CL and car-part.com to look for a donor vehicle. I’d probably try to find a radiator support, fenders, and hood. Even if you gotta roll around two-tone like @JakeJake, at least you have straight sheet metal and don’t need to worry about the parts you’re putting on getting damaged due to the current sheet metal condition.
    Nimitz_[OP] and JakeJake like this.
  26. May 30, 2025 at 7:28 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I blame the turtle pace that my personal projects tend to take on. Someday the truck and camper will be Porsche guards red. Maybe yellow. Maybe some lowrider style lace work.
    @Nimitz_ my local yard didn't even charge me for the small headlight filler panels and a pile of other stuff. I harvested a whole front clip, hood and one fender in about 45 minutes. Totally worth it if you can find something in your area.
  27. May 30, 2025 at 8:44 PM
    Nimitz_
    Sam
    Seattle-ish
    Already doing it but not sure what fits the DCs. Also most of the time they get stripped pretty fast.
  28. May 30, 2025 at 9:15 PM
    Nimitz_
    Sam
    Seattle-ish
    What’s the best way to find something in a yard? The closest dual cab on car-parts is 700 miles away
  29. May 30, 2025 at 9:42 PM
    Really depends on your location. Sometimes just searching “tundra parts truck” on FBM and CL will get you much closer private-sale examples. Maybe expand your search to OfferUp and/or other sale outlets. LKQ is a choice @The Black Mamba posted more info on how to setup alerts for LKQ Online’s new parts trucks in a previous thread very recently.
  30. May 31, 2025 at 2:33 PM
    bfunke
    bfunke Tundra Curmudgeon
