Throttle by wire to throttle by cable conversion
Discussion in '1st Gen Tundras (2000-2006)' started by 10_Points, May 29, 2025.
  1. May 29, 2025 at 5:28 PM
    10_Points
    10_Points [OP] New Member
    Kilen
    2003 Tundra Access Cab V8
    Zf6 650 6 Speed Manual Transmission and NP-271 Transfer Case
    Does anyone know how to put a throttle by wire throttle body on a 2uz-fe 4.7-liter v8? I've been looking and searching but I can't find anyone who's done this. I just hate electronics and want an extremely responsive throttle body
  2. May 29, 2025 at 5:51 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Supras, SCs amd IS300/JZ types have them. Driftmotion, rad dan drift and suprastore among others. You may need more electronics though, piggy back or something to intercept the ECU signal.
  3. May 29, 2025 at 6:34 PM
    The 2000-2002 or so had a physical throttle cable. Have you tried a banks pedal monster?
  4. May 29, 2025 at 6:36 PM
    10_Points
    Kilen
    Only the 3.4l v6. All 4.7l v8 tundras had throttle by wire
  5. May 29, 2025 at 6:37 PM
    Negative ghost rider
    bfunke, PNW15 and FrenchToasty like this.
  6. May 29, 2025 at 6:39 PM
    10_Points
    Kilen
    Weird. That means the one I looked at was converted. Would a 2000-2002 throttle body fit to my 2003?
  7. May 29, 2025 at 6:39 PM
    Fit? Sure, but the computers ain’t the same
  8. May 29, 2025 at 6:45 PM
    10_Points
    Kilen
    Is it a fully mechanical throttle body (2000-2002)? Some of the throttle by cable were "hybrid". They had mechanical cables but the computer still opened the butterfly. The cable could only open some of them 10%
  9. May 30, 2025 at 6:46 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    On my '00 the cable goes to the throttle body but it doesn't control it directly. With the truck off, the cable does not move the butterfly
    shifty` likes this.
  10. May 30, 2025 at 6:56 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    shifty` likes this.
  11. May 30, 2025 at 7:02 AM
    Helped on mine also. Also helped fix other people who found they had to push the pedal to halfway, and then the truck would jump.
