Build or just me talking to the walls or something
Discussion in '2.5 Gen Builds (2014-2021)' started by Totmacher, Dec 26, 2021.
  1. Dec 26, 2021 at 4:48 PM
    Totmacher
    Totmacher [OP] New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    placeholder while I think of more...
    Had the truck less than a month but already added bumper and have a few other things on order.
    Told myself I was going to keep it stock when I bought it.:rofl:
    2018 Limited 4x4.
    pics coming eventually.
    Started so far.
    1. fluid changes ongoing since I don't know what maintenance previous owner did.
    a. ATF (drain & fill with Toyota WS) It was pretty dark, may do again in a few months.
    b. front & rear diff oil (Amsoil)
    2. CBI front bumper.
    3. RCI skidplate(s).
    4. SS3 fog lights.
    5. Pair of 8" light bars (some chinese things from Amzon)
    6. DIY fuse panel and 3D printed switch panel
    7. 2.5/1.5 lift (5100/5160, shackles)
    8. wheels & tires: finally found something in stock that I liked. 295/70-18 Yokohama M/T on Method 314.
    9. solved some rattles and stuff using the magic of zipties.
  2. Dec 26, 2021 at 4:55 PM
    Order Valhallas cat protection plates.
    Hbjeff likes this.
  3. Dec 26, 2021 at 6:20 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Congrats!
  4. Jan 12, 2022 at 8:14 PM
    Totmacher
    Daniel
    West TN
    Some
    Discovered that RCI skid plate has to be trimmed to fit with a CBI Baja bumper.
    Aluminum skid so i just left the raw edge.
    And, yes, my cut is crooked.
  5. Jan 12, 2022 at 9:26 PM
    Totmacher
    Daniel
    West TN
    Some
    Also partially debadged recently.
    That big 5.7 iforce tag on doors was too much for sure.
    (Wood under tires was just making it easier to roll under while i installed the skidplate)
    V@pors likes this.
  6. May 23, 2022 at 8:31 PM
    Totmacher
    Daniel
    West TN
    Some
    Installed suspension goodies.
    Front got 5100s reusing stock springs.
    Rear got Coachbuilder +2 shackles, abs wire extension bracket (DIY), Bilstein 5160 rear shocks, and modified a Fox roost shield to protect driver side shock shaft.
    Got roughly 2.5" lift in front and 1.25" in back.
    Had to rotate the TRD sway bar mounts on the axle to gain some clearance from the leaf spring at full droop. Because of the shackles, leaf might still touch my exhaust and/or sway bar but only when I flex it out.
    With the resi piggybacked on the shock body, mounting the roost shield the normal way it's intended to go (clamped on near lower shock mount) means shield would hit the bottom of the resi on hard compression like stuffing the back wheels. Confirmed the truth of it even after cutting a few inches length off the shield by slowly flexing it through a ditch in the yard. So I cut the shield even shorter and mounted it upside down. By cutting away the screw holes and a little extra, it's basically a snap fit over the shot body and some zipties are enough to hold it now.
    Toe404 likes this.
  7. May 24, 2022 at 1:27 PM
    Totmacher
    Daniel
    West TN
    Some
    3d printed a panel for switches behind the shifter and moved rear window switch.
    Welded up a mount for fuses/relays to run lights and whatever other accessories I want in the future.
    Florida AF, AZTundra and Toe404 like this.
  8. Aug 25, 2022 at 2:50 PM
    Totmacher
    Daniel
    West TN
    Some
    RCI transmission skid and cat shields added.
  9. Sep 12, 2022 at 7:08 PM
    Totmacher
    Daniel
    West TN
    Some
    @COTundra23 I'm glad we got your exhaust on smoothly. Installed on my truck in 30 minutes...
    ... plus 3.5 hours not counting trips to stores dealing with a bolt that sheared. The very last bolt that would have finished the job. :rofl:
    Felt it binding, tried to back it out and that's when it broke. Was able to get out the bolt fragment and retap the hole. Went to 3 stores to find right size bolt. When i torqued the new bolt on same hole, the welded nut cracked so the new bolt wouldn't get tight enough. :censored: Rather than go to store again, found a skinnier bolt in my drawer to run through and use regular nut & washers behind the cracked weld nut.
    Slathered muffler putty in flanges while i was at it since i was reusing old gaskets.
    Btw, i did start it with no muffler. Sounded awesome at idle but waaay too loud.
    COTundra23 likes this.
  10. Sep 12, 2022 at 7:11 PM
    Totmacher
    Daniel
    West TN
    Some
    Letting a helper help but also stay out of my way. :rofl:
    BreyTundy, Reddawg1100 and COTundra23 like this.
  11. Sep 12, 2022 at 8:24 PM
    COTundra23
    COTundra23 New Member
    Oh man…. What a pain. Sorry you had to deal with that!! But looks like new (ish) now lol
    glad you made it home safely and that were able to have a good success story from this forum!
    Totmacher[QUOTED][OP] likes this.
  12. Sep 13, 2022 at 10:26 AM
    Totmacher
    Daniel
    West TN
    Some
    This is what the 3 foot difference in wheelbase from 4Runner to Tundra looks like fitting in a garage. LOL.
    Parked with back wheels lined up. Funny that they have almost the same amount of overhang behind the rear wheels.
    Part_time and COTundra23 like this.
  13. Sep 28, 2022 at 6:05 AM
    Totmacher
    Daniel
    West TN
    Some
    For historical reference that's not even on my Tundra...
    The plastic sheets I used to DIY skid plates on the 4Runner were ultra high molecular weight polyethylene (UHMW PE), anti-static grade, black.
    Some 3/8" and 1/4" thick.
    A 2ftx4ft sheet of each did engine, mid, & gas tank skid with some leftover material.
    Only added about 15lb to truck including the 1/8" flat bars I welded to reinforce OEM skids & help fasten the plastic sheets to.
    https://www.mscdirect.com/product/details/86209947
    https://www.mscdirect.com/product/details/86209939
  14. Sep 16, 2023 at 5:55 PM
    Totmacher
    Daniel
    West TN
    Some
    a few pics to add.
    Stuff done of the summer so far.
    Pair of reverse lights in center plastic section of bumper.
    Cleaned and painted front calipers.
    Cleaned outside and in.
    Cut some foam out from under back seats to make space for stuff.
    Got 5% tint on rear glass and sunroof.
  15. Sep 16, 2023 at 6:00 PM
    AZTundra
    Paul
    Phoenix, AZ
    Nice work. Best switch bezel I've seen on here so far.
  16. May 29, 2025 at 10:50 AM
    Totmacher
    Daniel
    West TN
    Some
    Haven't updated in a bit. Think I was just putting things in the what have you done today thread.
    Needed brakes. Hawk LTS pads all around a couple months ago. Did Hawk front rotors too. Slotted, not drilled. Rear rotors were good enough to leave alone. Got a tube of the fancy Toyota black brake & rubber grease too for the job.
    Didn't like ride on 5100s so I got Dirt King 2.0 front and rear plus UCA last summer. Happy so far almost a year on. Certainly an upgrade from 5100s.
    Added a new sticker too. I say it to my kids when they whine so they insisted i get it. Lol.
    TNThunder likes this.
  17. May 29, 2025 at 6:46 PM
    TNThunder
    TNThunder New Member
    Colten
    TN
    2017 Inferno SR5 Off-Road
    Truck is looking good :thumbsup: did you cut out under the rear seats for storage?
  18. May 29, 2025 at 8:42 PM
    Totmacher
    Daniel
    West TN
    Some
    Yup.
    Measured out rectangles I wanted, marked corners, then cut a X across just deep enough to get through carpet.
    Then folded up the carpet flaps and cut out the foam. Left triangle carpet flaps attached.
    Had some scraps of wool pad I cut to put down on metal floor to help with chance of noise.
    Then pushed down the carpet flaps to give a bit of a finished look to it rather than seeing cut edges of carpet. Set my stuff in place to hold down carpet flaps.
    I have squishable items across top like hoody, towel, or folded tarp so it goes against seat bottom to reduce chance of things bouncing out of their spots when i hit potholes or ruts too hard.
    A compressor and air hose and tire plug kit fits nicely in 1 spot.
    I added a cutout in middle too since that pic above was posted. Sized it to be snug fit on a socket set.
    TNThunder[QUOTED] likes this.
  19. May 30, 2025 at 4:21 AM
    TNThunder
    Colten
    TN
    It looks good! I have been wanting storage back there so that is going on my list to do. Thanks
