Sound deadening mats
Discussion in 'Audio & Video' started by Okietundra, Mar 17, 2025.
  1. May 26, 2025 at 8:19 AM
    Wallygator
    Did you completely cover those areas with the mats or only put random tiles on those areas? Asking because I want to buy only the amount of material I need for the doors and the back wall.
    bulldog93 likes this.
  2. May 27, 2025 at 11:04 AM
    DeepBushCaboose
    DeepBushCaboose New Member
    Michael
    Austin, TX.
    2020 Black Platinum Tundra
    I'm partial to https://www.secondskinaudio.com/ myself. I've used several different brands before and it seems the easiest to work with, especially their CLD product. I really like the luxury liner pro which is a CCF & MLV combined.
  3. May 29, 2025 at 4:01 PM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    Used Kilmat 80mil fr/theScamazon; applied to inside of outer door metal wherever I could get hand/part forearm to reach.
    18Sft [17 shts of 10x16"] was under $40 and inner doors took about 6 sheets...no problem w/install...cleaned surfaces w/water sponge, followed by dilute Dawn, clean water sponge. Let dry, then papertoweled w/ Isopropyl alcohol.
    Dont need rollers they all want to sell; since inner access is limited, cant see leverage from 6" long handle being much better than a 3/4 or 1" ID PVC pipe cut to length of middlefinger. Just press w/minor roll where you can...not a fine science.
    Didnt go cray w/it and after closing cab and blasting speaks w/various tunes, you might find add'l spots to apply small patches.
    Even w/bk cab wall left to do, i'll still have enuf to do ALL again. Just to use it up, might apply small patches on inside of inner door sheet metal-...20250526_142357.jpg
