  1. May 28, 2025 at 1:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Damn things would collapsed the dining table lol
  2. May 28, 2025 at 2:04 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Yes, this is with stock leaf packs. I tow a lot with the truck, at least weekly if not more frequently, so the original leaf springs were fed up with life after 210k. I scored a sub 10k mile set of leaf packs from my little brother off a '21 crewmax, and swapped them in last year.
  3. May 28, 2025 at 2:30 PM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    I made something for you 2.5 gen owners in CAD. The nephew and I are bonding and I've been making side shots of tundras for him to color. Dropping the files to see what you guys think and feel free to compliment or criticize I'm open to both lol. I'm working on a baja 2.5 gen and a crawler but that's gonna be some other day as I need to finish up my beloved 1st gen.
    Drawings are scaled to 0.0369, 17" Wheels with stock ride height.
  4. May 28, 2025 at 2:35 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Nice! I like em...the tire size changes makes for some fun at stock height, for sure!
    Tripleconpanna and mayan like this.
  5. May 28, 2025 at 2:58 PM
    SAGE63
    San Diego County
    Porn
  6. May 28, 2025 at 3:10 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    How are you powering those? Amp or no amp? Just off the radio?
  7. May 28, 2025 at 4:26 PM
    centex
    centex New Member
    Scared the wife.
    Was jackassing around today and the truck threw the Christmas tree up on the dash and started shaking real bad. She was convinced I blew the motor. No knock, no smoke, no leaks. Noticed the afr’s were real lean just driving normal. Got home and read the codes. Just a bunch of o2 slow to respond and o2 out of whack stuff. Cleared the codes and did a burn out down the driveway. Back to normal.
    WAT valvebody install tomorrow. Then once I get my deposit back, ordering some 880cc injectors and bumping the boost.
  8. May 28, 2025 at 7:04 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Here are the measurements for the Coachbuilder Shackles Screenshot_20241007-135828.png
  9. May 28, 2025 at 7:14 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    How do you blow a motor with 56k on it?
  10. May 28, 2025 at 7:16 PM
    centex
    centex New Member
    He’s talking about upgrading to the Land Cruiser hvac blower motor. It’s brushless and puts out slightly more air flow.
  11. May 28, 2025 at 7:38 PM
    IsaiahCanada
    Isaiah
    Calgary, Alberta
    That makes more sense.
  12. May 28, 2025 at 8:33 PM
    timlovestacos
    timlovestacos New Member
    2015 Silver Tundra 4x4
    Finally upgraded from 5100s to 6112s with new ucas (before and after picture is below). The ride difference is insane between the two. Now I’m forever screwed…IMG_4405.jpg Image-1.jpg
  13. May 29, 2025 at 5:35 AM
    AREDRIG
    AREDRIG New Member
    Luis
    18 tundra double 6.5 barcelona
    Off the OEM radio at first then few days later the Sony went in. Made a difference with the OEM and also not pictured is the other Kicker tweeters that were suppose to go on center area but instead went to the corners. Im glad I made the mistake because the corner ones would not both fit in center spot, theyre much bigger.
  14. May 29, 2025 at 5:54 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Guilty!
    https://youtu.be/PSEzI4Pn7Ws?feature=shared
    First, you have to like to party. It involves meth, gravity, and a little sucking.
    This is how a water/methanol syphoning issue puts 1.15 gallons of boost juice into an oil pan overnight, destroying a perfectly good 61k mile motor.
  15. May 29, 2025 at 5:58 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I like to party
  16. May 29, 2025 at 6:11 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Where are you located? I’m selling my RAS.
    Tripleconpanna, BR73 and quintalope like this.
  17. May 29, 2025 at 8:20 AM
    amc_
    amc_ New Member
    Washington
    2018 Tundra Platinum CrewMax 4x4
    Western Washington
    Curious why you're selling the RAS?
    Tripleconpanna and BR73 like this.
  18. May 29, 2025 at 9:42 AM
    centex
    centex New Member
    Dropped it off to get the WAT Extreme valvebody install. Should be able to pick it up tomorrow.
  19. May 29, 2025 at 10:18 AM
    ZPhilip
    Philip
    West Chester, PA
    Got bigger leaf springs and don’t need it anymore.
    Tripleconpanna and HulkSmurf14 like this.
  20. May 29, 2025 at 11:17 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I pulled a ford out not once but twice. :p His front diff wouldn’t engage. IMG_8332.jpg
  21. May 29, 2025 at 3:09 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    There a road out of frame we can't see? Wife's thinking "if we sell the boat we could have a new truck":monocle:
    Corndog123 and bulldog93 like this.
  22. May 29, 2025 at 4:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    Does anyone have a link or experience with a replacement center console cover? My father in laws 2020 SR5 armrest is peeling up in the corner and he's looking for a replacement. I've searched online and Etsy, but the reviews seem to be hit or miss. Hoping anyone here has found one that gave great results. Thanks in advance.
    woods, Tripleconpanna and BR73 like this.
  23. May 29, 2025 at 4:44 PM
    centex
    centex New Member
    Valvebody is done. Shop said everything went smoothly. Can’t wait to drive it tomorrow and see how it runs.
    woods, Terndrerrr, bflooks and 9 others like this.
  24. May 29, 2025 at 4:55 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I replaced mine a few years ago, with one like this from ebay. I followed a few of the vids on YT. If memory serves, I think leatherseats.com has a YT vid on the replacement process.
    Overall, not to difficult. Remove the lid and disassemble. Remove old cover.
    Not necessary, but I applied a small layer of foam like this from HL.
    Apply new cover, reassemble.
    I used weldwood contact cement for the foam and cover.
  25. May 29, 2025 at 5:04 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Or you can take it to an Auto upholstery shop to recover
  26. May 29, 2025 at 5:14 PM
    phabej
    phabej New Member
    2018 Platnium
    Installed left grab handle.
  27. May 29, 2025 at 5:43 PM
    ZPhilip
    Philip
    West Chester, PA
    What’s the install cost run?
  28. May 29, 2025 at 5:59 PM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Removed the nerf bar style side steps, disconnected the led strip lights that lit them up white when the interior lights were on and yellow when the parking lights were on. IMO they looked really ghetto and I hated the so I was happy to disconnect them. I also disconnected the OPT7 led strip light that was between the tailgate and bumper that was brake, tail, turn, and backup lights. Really didn't like that thing either and I'm glad to have disconnected it. If we can manage to break this pattern of rain I'll take the heat gun to all of them and peel them off.
    Corndog123, woods, bulldog93 and 2 others like this.
  29. May 29, 2025 at 6:00 PM
    Someone here had one not too long ago. @Cthulhu maybe?
  30. May 29, 2025 at 6:04 PM
    2014 Black tundra
    2014 tundra sr5
    There is a road, I was on His driveway. He bought a place out in the boonies. And got his truck stuck trying to park his boat. With all the rain we got, it made the grass/ meadow swampy.
    Tripleconpanna likes this.
