3rd Brake Light
Discussion in '3rd Gen Tundras (2022+)' started by Rockpig, May 18, 2025.
  1. May 18, 2025 at 1:31 PM
    Rockpig
    Rockpig [OP] You did what?
    08 Limited
    Need to wire in 3rd brake light on a topper, pulled headliner and it's a 3 wire plug. Anyone know where I can get the matching 3 wire connector so I can make my own harness? Also it'll be wired into a 2 wire light, which of the 3 wires in the original connector would I use? Not looking to tap into the brake light harness, want to use the stock connector.
  2. May 18, 2025 at 3:50 PM
    gesekee19
    gesekee19 New Member
    Why not wire it to your 7-pin trailer hitch? Smartcap goes down to trailer plug and has a harness that plugs right in
  3. May 29, 2025 at 6:04 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    It's not that easy, or cheap. In my research, you have to wire in some kind of decoder box for each side of the truck. I can't recall the name, and they a couple hundred each.
  4. May 29, 2025 at 6:05 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Here's the write-up I did when I wired my 3rd brake light.
    https://www.tundras.com/threads/truck-cap-3rd-brake-harness.147874/
    Dave, who owned the website has since retired, he had a partner who can be found on TacomaWorld can still make a harness for you.
    Tundrastruck91 likes this.
  5. May 29, 2025 at 6:18 AM
    gesekee19
    RSI Smartcap and other brands literally sell a harness that plugs in behind the 7 pin harness under the truck. No splicing required, just a plug and play and still allows you to tow and plug in to the 7pin in the bumper. That’s how my third brake light is wired.
  6. May 29, 2025 at 6:31 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
  7. May 29, 2025 at 6:44 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Same experience as @gesekee19 here:
    I added a bed mounted tail/stop/turn LED strip from OPT7 and used their 7 pin to 4 pin plug and play harness here: https://www.amazon.com/OPT7-Extension-Connector-Compatible-2005-2023/dp/B0CNFZ7TBH
    Similar adaptor harnesses are available from other vendors as well.
    No decoder box(es) needed. :confused:
  8. May 30, 2025 at 3:27 AM
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
  9. May 30, 2025 at 9:25 AM
    estebanoss
    estebanoss New Member
    '23 Limited 4x4 TRD OR
    IF you do exhaust your options and want a quick solution; tapping the driver side tail light is super easy.
    If I'm not mistaken:
    Ground: White with black stripe
    Power: Solid blue
    This is how I wired my GFC 3rd brake light through the truck bed liner.
    GGoffroad's harness is another great option to get that dedicated line to the 3rd brake light.
    1lowlife likes this.
  10. May 30, 2025 at 9:45 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    The aluminum wire going to the tail lights, you are not supposed to tap it, says so in the manual, I guess.
  11. May 30, 2025 at 11:00 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You are correct Sir.
    Same colors as the 3rd brake light as well.
    The passenger side ground wire may be a different color depending on whether the truck has bed lights or not.
    Although this is an interesting option..
    22 Tundra Brake Light Wiring Tap Cable | Simplify Topper Install - GG.OFFROAD — GG OFFROAD
  12. May 30, 2025 at 11:57 AM
    BlackNBlu
    Rich
    MN
    Lilac? Seriously.
    If Toyota starts naming wire colors Puce, Chartreuse and Mauve in their electrical schematics I'm going to :puke:
    4x4_Angel likes this.
  13. May 30, 2025 at 12:21 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    You're on to something BNB.
    It was years ago I read that L stood for Lilac.
    But since I have nothing better to do right now, I looked into it.
    Pretty sure somewhere in my mind I was thinking of Lavender aluminum wiring..
    The L does indeed represent Blue.
    Now I need to go back and fix all my posts that I mentioned Lilac...:rolleyes::cool::(
    I relearned something today..:thumbsup:
  14. May 30, 2025 at 3:13 PM
    estebanoss
    whoops...
  15. May 30, 2025 at 3:15 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Gen 3 Tundras have aluminum wiring?:eek2:
    That's 2 things I learned today..:thumbsup:
  16. May 30, 2025 at 3:16 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    :rofl: but purple is darker than lilac. Guess they could have said light purple.... Just takes more space to type
