  1. May 27, 2025 at 6:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    On drivers side for our winter rain you could do a removable panel over fuse box yo divert the water. Nice hood!
  2. May 27, 2025 at 7:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    We’re relocating the fuse box so we may not even need it but we’ll see where it lands but that’s a great idea
  3. May 27, 2025 at 8:24 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    bulldog93 likes this.
  4. May 27, 2025 at 9:00 PM
    French Avocado
    Utah / Wyo
    For those with Rago (or similar) center dash mounting plates, what kind of mounting balls and length of arms do you use?
    HulkSmurf14 likes this.
  5. May 27, 2025 at 9:32 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    250,000 km oil change this weekend. And, showed my son how to change the serpentine belt and replaced the idler pulley and belt tensioner while we were in there. Good day of maintenance for the old girl! I already had the fumoto valve on the oil pan but i added the filter housing valve to make draining the oil mess free! Totally worth it if you change your own oil! The icing on the cake was using the funnel that screws into the oil filler tube. So nice not having to wipe up up drips and spills!!
    AZTundra, Corndog123, woods and 12 others like this.
  6. May 27, 2025 at 9:59 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Nice... looking more and more like a Raptor every day :D
  7. May 27, 2025 at 10:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    67D - aluminum balls and carbon fiber arms.
    Length depends on what you are holding with it, which set of holes you’re mounting to, and where you want that thing positioned.
    The “DPA” base fits the hole spacing on the Rago plate
    https://www.67d.com/products/diamond-plate-alternative
    RobertD, Pangaea, HulkSmurf14 and 4 others like this.
  8. May 28, 2025 at 3:09 AM
    phabej
    phabej New Member
    2018 Platnium
    Please update with photos, I'd love to see how it's done as I might install these in the future. Be great info to know what to do correctly.
  9. May 28, 2025 at 5:20 AM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    There are videos on how to do, decided to take up to dealer and have them do it, and front end alignment.
  10. May 28, 2025 at 6:18 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Ics ball mounts 20mm/bullet point arms. Length as mentioned depends on what you’re mounting and where you want it to sit.
  11. May 28, 2025 at 7:36 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I'm happy w/ my Toytec ones for sure.
  12. May 28, 2025 at 7:54 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
  13. May 28, 2025 at 8:23 AM
    AREDRIG
    AREDRIG New Member
    Luis
    18 tundra double 6.5 barcelona
    hey all Tundra owners! Not today but the past week. Huge difference and no NETFLIX yet or watchin shows at my lunchtime at work when its nice out but Im sure something will come up soon. Much much much better than the OEM radio/nav and it sure is plug and play no soldering unless you want the radio to play. I sometimes listen to local radio once in a while tho. So insted of soldering gun I used the connectors with solder and torched it with my cigar torch, hahahahahaha!
    CaptRussia253, bradj1, BR73 and 10 others like this.
  14. May 28, 2025 at 8:52 AM
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    Changed out the blower motor to the landcruiser replacement. I honestly can't tell a huge difference, but it's not like I did a before and after. OE one had 56K miles on it.
  15. May 28, 2025 at 9:51 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Hey @memario1214 just to clarify since eckstrom hasn't emailed me back. Looking at my truck, I'm highly doubting that I'll be able to use my coachbuilder shackles with the RAS, correct?
  16. May 28, 2025 at 9:56 AM
  17. May 28, 2025 at 9:58 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    +2 or +3 will work without modification. +1 will still work, but you would need to shave down the crossbar a bit. Out of the box a +1 and RAS do not jive though.
  18. May 28, 2025 at 10:01 AM
    250000yota
    Russ
    Berthoud, CO
    The man, the myth and the legend. Thanks. I have a set of 6112's, a used RAS HD set up and I believe +1's and +3's that will be going on the truck in the next few months. Might have to do some playing and possibly order the +2's. Hell I've got all the others, right? :rofl:
  19. May 28, 2025 at 10:04 AM
    memario1214
    Colton
    Missoula, MT
    :wave:
    Well I have +2" on the shelf when you're ready! :rofl:
  20. May 28, 2025 at 10:55 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Is this with factory leafs?
    250000yota[QUOTED] likes this.
  21. May 28, 2025 at 10:57 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hood just arrived, Lsk kit anytime today.
  22. May 28, 2025 at 10:58 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm going to need a second sock. So sexy!
  23. May 28, 2025 at 11:00 AM
    memario1214
    Colton
    Missoula, MT
    I don't know if @250000yota has OE leafs, but my feedback is based on OEM leafs.
  24. May 28, 2025 at 11:00 AM
    AZBoatHauler
    So.Arizona
    Damn. :bananadead::bananadead:
  25. May 28, 2025 at 11:28 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Need to open this up make sure it’s all there
  26. May 28, 2025 at 11:30 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Did the steering wheel leather wrap. Brand is loncky from Amazon. Had it on my previous sequoia. Liked it. Took about 3 hrs. Not bad for diy. Some wrinkling here and there. I dont mind.
  27. May 28, 2025 at 12:25 PM
    Stone Chingon'
    Stone Chingon' New Member
    BC
    East County SD
    2021 Crewmax 4x4 Limited
    Thank you- 17 x 8.5 Raceline Rogue +35mm offset.
    CaptRussia253 likes this.
  28. May 28, 2025 at 1:02 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hopefully the axles and shock package are ready soon.
    Mdl, Velocity72, OHwendTrd and 19 others like this.
  29. May 28, 2025 at 1:03 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    In the kitchen, I assume
  30. May 28, 2025 at 1:03 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s not the kitchen. :boink:
