How does the frame look on this 2006?
Discussion in '1st Gen Tundras (2000-2006)' started by BigTuna8695, May 28, 2025.
  1. May 28, 2025 at 5:05 AM
    BigTuna8695
    BigTuna8695 [OP] New Member
    05 DC Limited 4x4
    Hey, everyone! I am strongly considering buying this 2006 limited. Comes with a bed cap. It's at 200K miles and seems to be in decent shape. He did timing belt and water pump at 180K. Ball joints at 160. Bilstein lift. Can you guys take a look at the pics and video and let me know if you see any red flags. Carfax is clean. He seems to have taken great care of it with records of maintenance.
    The buyer is asking $11k for it.
    Frame video: https://imgur.com/a/H2XzVAC
    Pics: https://imgur.com/a/IdSNC5k
  2. May 28, 2025 at 5:08 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Looks to be in fairly decent shape to me. In the frame video, right at the 15 second mark, you can see that the inside edge of the frame doesn't appear to be a straight edge close to where the leaf spring mount is. I suspect there is a little delamination there, and you should look at the inside portion there to see how bad it is (mine has it too). Also check around the reinforcement plates on the inside of the rails. Obviously you need a new exhaust system too. I have the Dirty Deeds setup, it's been good.
  3. May 28, 2025 at 6:00 AM
    BigTuna8695
    05 DC Limited 4x4
    Thank for the reply! I am about a 24 hour drive from this truck, so I'm largely relying on photos for now. Pardon the ignorance, but where are there reinforcement plates on the inside of the rails? Are they along the entire frame? I'll ask for a video.
  4. May 28, 2025 at 6:01 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    The heck is this u-bolt doing there?
    Jack McCarthy likes this.
  5. May 28, 2025 at 6:07 AM
    pursuit2550
    pursuit2550 New Member
    It's on both sides. Looks like helper springs to me.
  6. May 28, 2025 at 6:08 AM
    The important parts of the frame aren’t shown where the trouble areas are located but on first glance, a lot of that looks like dirt/surface rust. You’re probably okay to warrant a trip for a closer look.
    PNW15 likes this.
  7. May 28, 2025 at 6:08 AM
    BigTuna8695
    05 DC Limited 4x4
    I know he did the add-a-leaf lift. I'm not very knowledgeable on them- is that not where the U-bolt is supposed to be?
  8. May 28, 2025 at 6:09 AM
    pursuit2550
  9. May 28, 2025 at 6:11 AM
    BigTuna8695
    05 DC Limited 4x4
  10. May 28, 2025 at 6:15 AM
    kentuckyMarksman
    They are not along the entire frame. If you look inside the frame rail, under the area between the cab and the bed you'll see them. That's another common spot for issues.
    And I'm sure someone will come along and say to check the crossmember above the spare tire.
  11. May 28, 2025 at 6:51 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
