  1. May 27, 2025 at 5:45 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Yeah, I don't have any reference from before my recharge unfortunately. My original condenser had a leak and the system was empty, so I was able to take my evap coil out to clean it.
  2. May 27, 2025 at 5:47 PM
    Not trying to lecture, but it would be safer for Dale in the backseat. Less chance of him going through your windshield. I had a friend lose her cat that way.
    I measured 40 a few years ago but not sure how accurate this method is. This was right after I cleaned off the condenser. It improved by 10 degrees after I cleaned it. This reminds me I'm probably due for another rinse.
  3. May 27, 2025 at 5:51 PM
    I temp'd mine after doing the last coil cleaning. Wish I'd taken 'before' measures but I clocked in at 38. My garage is also 60% subterranean and fully shaded.
    oscardog86 and Dakillacore like this.
  4. May 27, 2025 at 5:59 PM
    Did you put in new O-rings and were they from Toyota? I’ve been thinking about getting mine replaced since they appear to slowly leak from the dye test.
  5. May 27, 2025 at 6:01 PM
    des2mtn
    Shady Grove
    Tonto cover
    O-rings from RockAuto
  6. May 27, 2025 at 6:06 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Wow, yeah mine gets nowhere near 40--and it hasn't been hot yet where I am. I did foam clean my condenser too but haven't sprayed/hosed it down. It only improve a couple degrees or so if any after I cleaned everything. Curious to see my results after a recharge
    oscardog86 likes this.
  7. May 27, 2025 at 6:18 PM
    My uncle installed aftermarket A/C in his 1971 C10 pickup in Las Vegas and in the middle of summer it would kick out 36°. I'd have your levels checked if you're sure everything is clear. Go to an actual auto A/C specialist to have it checked.
    Dblock500[QUOTED] likes this.
  8. May 27, 2025 at 6:39 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Absolutely. Better yet, in a securely fastened kennel.
    We don't live that life though. Here for a good time, not for a long time.
    RUSTYNUTS, shifty`, Sirfive and 5 others like this.
  9. May 27, 2025 at 7:15 PM
    I drafted that message a few days ago but never finished. Forgot about it. This forum software will save your draft forever.
    Anyways, I get it. I used to let our dogs ride in my backseat some. They would prefer to be up front but I realized it was safer for them and me if they were not distracting me up front. I had an ex GF that got pulled over for having her dog in her seat with her. Can't remember if she got a ticket or not. Some people won't even let their dogs in their vehicles unless they are in a kennel but I never did that.
    JakeJake[QUOTED] and oscardog86 like this.
  10. May 27, 2025 at 7:22 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Is that OEM setup? Can I ask you the same
    “I've been curious how much resistance there is with fresh wheel bearings when spinning the hubs? Do they spin easily a half dozen times like a bike wheel or are they still relatively stiff and maybe spin once or twice all the way around?
  11. May 27, 2025 at 7:29 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I honestly have no idea. I imagine it’s not like a bike. If you’ve spun a wheel while jacking the truck up it’s like that, but not grimy. Just smooth. Not OEM went with koyo bearings.
    RUSTYNUTS and Kimosabe[QUOTED] like this.
  12. May 27, 2025 at 7:55 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Sunday....pulled the short trailer and mowed 5 yards. We'd already done 2 yards using my dad's (formerly my) GMC Canyon.
    Rained out on the last two planned yards but 7 yards mowed is pretty good for us.
    Learning better trailing backing techniques.
    Using a new-to-me "Toyota" keychain. I really like this one! Pics to come.
    MooreKen likes this.
  13. May 27, 2025 at 8:01 PM
    grzzlr
    grzzlr New Member
    2002 AC V8 TRD 2x
    The transmission oil pan was weeping all over but not dripping but I changed it today. Looks like it was done in the past with an aftermarket gasket, I used the toyota form-in-place stuff.
    Took a bit but I found good resources here as usual and it went with out issue. I found a small spot where whoever worked on it before was prying and made a burr on the transmission. I filed it off hopefully it won't be a problem.
    Also replaced the sway arm links but I still have a click sometimes I suspect the inner-tie rods which is fine since I have a new steering rack waiting to be installed. Screenshot 2025-05-27 at 7.58.32 PM.png Screenshot 2025-05-27 at 7.58.45 PM.png
  14. May 27, 2025 at 8:40 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Good question. I can lft the truck tomorrow to get you a better idea.
    My worn bearing would spin freely, I also had no play at 12, 3, 6, and 9 o'clock positions. I heard my bearing most when going to a complete stop and turning. I've only put about 20 miles since install. I can only hear tires now
    oscardog86, KNABORES, bmf4069 and 2 others like this.
  15. May 27, 2025 at 8:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I believe they were the OEM manufacturer Toyota used
    khooiii[QUOTED] and KNABORES like this.
  16. May 27, 2025 at 8:48 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Thanks for the responses. That’s helpful.
    I have what I think is an aftermarket hub and spindle on one side and there is quite a bit of resistance (especially compared to the other side) when trying to spin it. I also have two knuckle and hub assemblies off a wreck and I’ve been wondering if they’re still in good condition or if I should rebuild them before mounting them. I’m a bit jealous of the fresh assemblies. I might have to do the same.
  17. May 27, 2025 at 9:12 PM
    Dblock500
    DMV
    That's what I need, haven't been able to find specific AC specialist around here though, all shops are just general auto shops. I'll looking a little deeper or just go with a reputable shop
  18. May 27, 2025 at 9:23 PM
    AmericanKing06
    New Mexico
    How many miles are on the wrecked units? Replacing the spindles ain't that bad of a job. 1st gen bearing are a pain to replace compared to other Toyota models. I saved myself the headache. Plus a couple of stories people not getting the bearing to seat properly. FR33LANCEFAB is highly recommend. My only regret is not doing it sooner.
  19. May 27, 2025 at 10:05 PM
    sportbike37
    sportbike37 New Member
    FL
    Upgraded the battery from 24F to 27F and installed a new battery tray from Toyota - Part No.: 74431-0C020
  20. May 28, 2025 at 1:13 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Can check the rear retainer is positioned to mate with the oil seal by popping out the ABS sensor and seeing that tone ring is dry after a while.
    Kimosabe[QUOTED] likes this.
  21. May 28, 2025 at 1:15 AM
    ToyotaDude
    ToyotaDude Member
    Or rent for free a set of guages from the LAPs and give it a check. Sounds like if it has a temp drop there is some freon but may be low if only a 20 degree delta between ambient and AC.
  22. May 28, 2025 at 4:59 AM
    My worn out front wheel bearings also felt smooth on the truck, but notchy and not smooth once the tire and CV axle where disconnected from it
    Koyo is OEM, I used them when replacing mine
    It is quite the process to press them in and out. But if this monkey can do it....
    Kimosabe[QUOTED] and oscardog86 like this.
  23. May 28, 2025 at 5:03 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Whatcha gonna do with the OEM spindles that could be used as part of a future 4WD conversion? Asking for a friend.
    BroHon, bmf4069, oscardog86 and 2 others like this.
  24. May 28, 2025 at 5:56 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Firm believer in replacing things while they’re out. I normally wouldn’t replace the spindle but it might have been bent from shenanigans lol.
    455h0le_dachshund and oscardog86 like this.
  25. May 28, 2025 at 5:57 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Sitting at the shop. I can’t remember if they still have both. I’ll grab em for ya.
    BroHon, bmf4069, shifty` and 2 others like this.
  26. May 28, 2025 at 6:11 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    :hearteyes:
    BroHon, bmf4069 and khooiii[QUOTED] like this.
  27. May 28, 2025 at 7:54 AM
    Dirt Ferguson
    Dirt Ferguson New Member
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    Not today, but over the last month or so I replaced front and rear suspension components: Dobs IMS Coilovers and rear shocks, Suspension Maxx front links and an Archive Garage Shackleton MD leaf pack. RRW RR7-S wheels (0 offset, -25) w Falken Wildpeak 275-70-17 rubber.
    How it started....
    New coilovers and rear shocks , but still original leaf packs
    New suspension and leaf packs
  28. May 28, 2025 at 8:02 AM
    I got to the 2nd pic and was, like, "damn..."
    Then I got to the last pic and was, like, "oh hell yeah"
    Those front wheels look like they're poking overly hard. 17x8.5 and -25 == 3.77" backspace is wild*. Any reason you went with that choice?
    Cap might seal and look better if you pop off the plastic rail covers and replace with double-bubble seal.
  29. May 28, 2025 at 8:14 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Edited: Is it bad that I like the OEM wheels better?
    BroHon, khooiii, abcinv and 3 others like this.
  30. May 28, 2025 at 8:17 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Yes, lol
    Nah to each there own but I like his new wheels and tires with the upgraded suspension.
