Hood Bulge Howling after installing light bar.
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, May 17, 2025.
  1. May 17, 2025 at 11:58 AM
    brkncly
    brkncly [OP] New Member
    Oregon
    I installed a 40” S8 Baja Design light bar in my 2020 CM hood bulge using the SDHQ light bar mount made specifically for the Baja Design light bar. Using the SDHQ made specifically for the 40” S8 Baja Design light bar, the instructions says to cut three 3-1/4” holes to access the mounting screws for the hood bulge. Now I notice when. there’s a little wind or at high speeds I get a howling noise because of the air flow going through the hood bulge, any body experience this and have a fix for it?
  2. May 17, 2025 at 1:18 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Is this the 40” Baja designs light bar with the SDHQ mount?
  3. May 17, 2025 at 2:56 PM
    brkncly
    Oregon
    Yeah it is.
  4. May 17, 2025 at 3:11 PM
    brkncly
    Oregon
    These are the three access holes that I drilled per SDHQ instructions.
    reywcms likes this.
  5. May 23, 2025 at 9:53 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    How about putting some (painter's) tape to cover the holes and see if that stops that howling? If so, replace the tape with some closed rubber grommets:
  6. May 27, 2025 at 2:16 PM
    brkncly
    Oregon
    @713Tundra good idea, I'll try the painters tape first. Where did you find those closes rubber grommets? Thanks
    reywcms likes this.
  7. May 27, 2025 at 2:42 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Amazon or Ace
    RobertD likes this.
  8. May 27, 2025 at 4:44 PM
    I dont have any howling noises with mine. If the painters tape doesn't stick, use the foil tape that's used for air conditioning. Lowes or HD carries it.
